![]() Join Date: Sep 2006
Running GT2871R
Alright I have been searching all day and have really only found setups for maxing out this turbo. What I would like to know is could I get this turbo and run it on stock injectors and maf between 8-10psi without running into problems? I am looking to buy a new turbo because my T25 is gonna take a shit and I would like to just put the money toward a good one and not have to spend money twice. I am not looking for huge power or anything right now just for a good working engine as I have just built an SR and at this point just want it to run reliably.
if ur gonna run low boost with stock injectors i see no problem just dont turn it up until u get 550ccs and a new maf
10psi is 10psi whether its comming outta a t25 or a gt35 |
![]() Join Date: Sep 2005
He is right, but he is wrong and wrong as hell!
$=10psi -T25 @=10psi-GT35 $$$$$$$$$ T25 flow a minute @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ GT35 flow a minute So in about 5 minutes your done. I'm an idiot say it with me.
![]() Join Date: Nov 2006
i was runnin around with one for a few days on 7 lbs and i didnt have a
problem with detonating, just make sure you run the proper oil lines, or the right sized fittings those garrett ball berings dont like alot of oil pressure |
If you can't afford to do all the supporting modifications, just get another t25 for the time being. It'll cost you like $150 and a few hours of your time and you can always sell it when you are done with it. I personally wouldn't run the gt2871 without engine management.
#11 | |
![]() Join Date: Jun 2004
Everything really needs to be all together and working well, for things to go well. Engine management and deachwerks injectors are about the price of another swap, which you'll be doing, if you dont, then you'll be stuck at stock again. Unless you DONT want to spend the money, in which case, get out of the game, and get a camry.
[email protected] |
#12 | |
I'm with Flybert and johngriff... just wait till you got the money for the needed supporting mods. T25 is cheap and quick to replace, and it's better to buy a T25, and wait and still be able to drive, then buy a gt28, slap it on, and grenade your engine the first time you hit boost.
![]() Join Date: Oct 2006
+1 ^^^
im with u guys... dont get in over ur head it will cost u more in the long run.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
#14 |
just use the t25 till it craps out, take good care of it and it will last you a while. waite till you get the supporting mods, fmic, injectors and management. that get the 2871r
#15 |
![]() Join Date: Dec 2006
Get a rebuild off of EBay they are only 60 bucks Ive rebuilt 4 of them so far with no problems and very easy to do
#16 |
Keep the boost low, the 2871 would already make a little more power at the same boost as your t25 did. If you want to play it cautiously, buy some injectors and fuel management before you turn it up!
T25's are infamous for taking a dump...Its just cause there so dang old. Good luck!
