Old 08-24-2007, 06:54 PM   #1
Matrix021
Matrix021 is an unknown quantity at this point
Send a message via ICQ to Matrix021 Send a message via AIM to Matrix021 Send a message via Yahoo to Matrix021
Unhappy Help with check engine light
Hey all. I have a 98 240sx and the service engine soon light came on. I used an OBDII scanner to pull the codes and there aren't any! That's zero codes pulled. Any ideas on what's going on? Thanks in advance.
And that's my 2 cents...
Matrix021 is offline   Reply With Quote
Old 08-24-2007, 07:21 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Is the light still on? Tried manually pulling codes instead of using the scanner?
CLICK HERE!!!
Old 08-27-2007, 02:23 AM   #3
Matrix021
Yeah... the light is still on... I'm going to pull them manually and see what happens. I was wondering if the light could mean something else. Like my mom's honda, it turns on whenever you're due to take it to the dealer for it's 30K, 60K, etc.... But on her car, there's actually a Check Engine Light and Service Engine Light. Also, it's actually my friend's car and I know nothing about the instrument lighting for the S14s... so I don't know what will trigger the light and if there are separate lights for service and CELs. I hope it's nothing major though... you know how CELs can ruin your day with an OBDII car. I'll stick to my S13.... lol... smog crap just seems to be a hell of a lot cheaper....
Thanks for responding!
Old 08-27-2007, 02:55 AM   #4
fliprayzin240sx
Manually pull it, get to the ECU, turn the screw all the way right with the ign power on (dont start the car, just power on), flip the screw all the way back and look at the cell light. Itll bling a certain times. Slow and fast. Count how many slow blinks and fast ones. Slow ones are the first digit of the codes (10s) and the fast onea are the second digits. To clear the code, flip it screw again and back, then start the car, should clear the codes unless something is tripping it.
CLICK HERE!!!
Old 08-27-2007, 03:25 AM   #5
MelloS13
MelloS13's Avatar
MelloS13 will become famous soon enoughMelloS13 will become famous soon enoughMelloS13 will become famous soon enoughMelloS13 will become famous soon enough
Retrieving codes :
A long flash (.6 second) will indicate tens column digit. Short flashes (.3 second) will indicate ones column digit. for example: 3 long flashes followed by 5 flashes of red LED ( or CHECK ENGINE light) indicate a Code 35
TROUBLE CODES:
Code / System-Circuit Affected / Probable Cause
11 / Crank Angle Sensor / Loss of Signal
12 / Mass Airflow Sensor / MAF signal High or Low
13 / Coolant Temp. Sensor / Open-Shorted Circuit
14 / Vehicle Speed Sensor (VSS) / No VSS Signal
21 / No Ignition Reference Pulse / Loss of Primary Signal
31 / ECU / Signal Out of Range
32 / EGR Sensor (Calif.) / No EGR Action
33 / O2 Sensor / Open Circuit Or High O2 Signal
34 / Knock Sensor / Open-Shorted Circuit
35 / No Malfunctions Recorded are available on all models / No Faults Detected.
MelloS13 is offline   Reply With Quote
