Old 09-14-2007, 08:05 PM   #1
Borund
Borund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymore
Send a message via AIM to Borund
sr20det Compression
In a ballpark range, what should be the test result #'s of a good compression sr20det? doing the compression test while the engine is cold(hanging from a cherry picker) Cuz im about to do a test, and need to know what im looking for? Thanks. :]
Borund is offline   Reply With Quote
Old 09-14-2007, 08:30 PM   #2
KawBoy
KawBoy's Avatar
KawBoy is making a name for him/her selfKawBoy is making a name for him/her self
128 psi service limit, 156 psi max (Brand New Motor)
For any S13-S14 SR20DET
No more than 5 psi variation between cylinders.
KawBoy is offline   Reply With Quote
Old 09-14-2007, 08:54 PM   #3
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
I'll tell you from personal experience and I have atleast 20 engine swaps under my belt that a cold compression test from a feshly bought used engine that hasn't been run yet or in a while typically the kind you by from who else but an importer of used JDM engines that those numbers can be all over the place 50, 100, 200, 85 example but still be a good engine, its hardly ever gonna give a correct reading until the engine has been warmed up thouroghly then you go back and check the numbers and the could change to 155psi accross the board without adding oil which is cheating to bring the numbers up, seen it for myself many times.
Old 09-14-2007, 08:55 PM   #4
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
But to answer yoru question consistancy between all cylinders is what your really want along with numbers around 150psi.
Old 09-14-2007, 09:20 PM   #5
Borund
Here is a picture of the engine i plan on getting.
