Old 09-23-2007, 11:58 PM   #1
RPSil13
RPSil13 is making his/her stupidity well-knownRPSil13 is making his/her stupidity well-knownRPSil13 is making his/her stupidity well-known
Turbo Timer Problem
tomorrows street sweeper day and i go to turn on my car and it wont start, it usually takes a few tries to start but i sat there for a good 10 mins and nothing, the car wont start all of a sudden, then i looked at my timer and it glows but no numbers appear, since its connected to the ignition might this have something to do with the car not starting. any help greatly appreciated thanks, guys
RPSil13 is offline   Reply With Quote
Old 09-24-2007, 12:06 AM   #2
blownmotor
blownmotor's Avatar
blownmotor is on the path to ruinblownmotor is on the path to ruin
It's not the timer check wiring and fuses I would also check for spark
blownmotor is offline   Reply With Quote
Old 09-24-2007, 03:06 AM   #3
RPSil13
but why would the timer stop showing the display, right away the first time i put the key in the display lit up but after cranking it a few times the display went blank, and then when i turned the car off the display stayed lit up but no display
Old 09-24-2007, 03:12 AM   #4
RPSil13
the timer is still glowing with no numbers displaying, and i took the key out like 4 hours ago, wha could possibly cause this
Old 09-24-2007, 03:27 AM   #5
AznDrftr.
AznDrftr.'s Avatar
AznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond repute
Send a message via AIM to AznDrftr. Send a message via MSN to AznDrftr. Send a message via Yahoo to AznDrftr.
Make sure all wires are connected firmly and not touching anything else. But i wouldnt think it would cause for it not to start.
So when you put the key in and turn it, does it make a sound at all?
Does it try to crank and turn over?
Post step by step to get further with this.
AznDrftr. is offline   Reply With Quote
Old 09-24-2007, 08:40 AM   #6
whippet
whippet is on the path to ruinwhippet is on the path to ruin
If it's still glowing 4 hours later, maybe it killed your battery. Is it turning over at all?
whippet is offline   Reply With Quote
