Old 09-27-2007, 10:53 AM   #1
nanner47
nanner47 will become famous soon enoughnanner47 will become famous soon enoughnanner47 will become famous soon enoughnanner47 will become famous soon enough
"popping" when slowing down
Ive got a 90 s13 hatch, recently when im driving and i break rather violently.. i hear a sort of "pop/clunk" coming from the front suspension... it also happens when i turn the wheel all the way to the left turning.Are these common symptoms of bad ball joints or maybe tie rod ends??... im worried that the threads on the left side of the rack are worn out causing the shaft to make this noise when im turning and breaking... idk.. any feedback will be greatly appreciated.
nanner47 is offline   Reply With Quote
Old 09-27-2007, 11:24 AM   #2
ayuaddict
ayuaddict's Avatar
do you have cut springs/aftermarket springs? if so, when you re-installed them, did you put the rubber cover between the spring and the upper perch/mount? also sometimes the spring will cut through this rubber cover. either scenario can cause the spring to make funky noises, although this not not necessarily unsafe.
keep in mind however, the noise can be caused by a variety of things but this is the best case scenario, and what i would check first.
Old 09-27-2007, 01:01 PM   #3
DP_Michelle G
DP_Michelle G's Avatar
DP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really nice
Tension Rods!!
BC RACING COILOVER REVIEW
DP_Michelle G is offline   Reply With Quote
Old 09-27-2007, 02:22 PM   #4
nanner47
nope the car is bone stock.... ill check both tension rods and ball joints..
Old 09-28-2007, 01:36 AM   #5
YUNG DRIF
YUNG DRIF's Avatar
YUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to behold
Send a message via AIM to YUNG DRIF
Originally Posted by DP_Michelle G View Post
Tension Rods!!
Like the man said Tension Rods replace them, dont get new bushing
YUNG DRIF is offline   Reply With Quote
Old 09-28-2007, 08:16 AM   #6
nanner47
why shouldn't i replace the bushings while doing the tension rods?
Old 09-28-2007, 09:16 AM   #7
slow_sr20
slow_sr20's Avatar
slow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant future
because the new tension rods shold come with bushings-buy spherical ones-they are a great improvement over stock mushy ones.
slow_sr20 is offline   Reply With Quote
Old 09-28-2007, 01:06 AM   #8
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
Jack up your car and just try to see if anything (ie. tie rods, control arms, tension rods, etc) wiggles or has play. Also, check your bushings; If they're bad, you might have periodic metal to metal contact.
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 09-28-2007, 01:20 AM   #9
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
I had that issue once, and checked everything. Happened to be that my stud in my hub was slightly tilted, causing the rotor to be slightly tilted. Barely noticable, but that was the issue. doubt its that, cause thats random, but just in case
jskateborders is offline   Reply With Quote
Old 09-29-2007, 12:50 AM   #10
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
Yes, without a doubt, this sounds like what has been mentioned before. Under braking (especially heavy braking), the chassis transfers alot of weight (forces) to the front suspension components in the forward direction. If any part could be rotated forward from the position it is installed in the forward/rear direction if it were to be loose (i.e. tension rod), then it will, in fact, move in that same manner when braking/accelerating with great force.
Like yung and slow_sr20 have mentioned, opt for any of the name brand tension rods with the spherical bushings as they make a world of difference under these same conditions. Just make sure you torque those nuts on the rods (in the neighborhood of 70-90 ft-lbs) so they don't reloosen themselves.
We hope this fixes your "popping"...I know it fixed mine!
bshotts is offline   Reply With Quote
