Old 10-01-2007, 08:00 PM   #1
2s4x0
2s4x0's Avatar
2s4x0 is on the path to ruin2s4x0 is on the path to ruin
sr20det problem
wondering if anyone has any ideas?
my car sputters, big time! anything from 3,000 rpm's and up. almost bogs down! wtf is wrong with it?
i have no leaks, tried every spark plug out there. its running really rich, it has back fired even shooting flames.
i basically can't push it over liek 25% throttle without it bogging/ sputtering.
its pisssing the fuck out of me.
any suggestions
let me know if you need more info to the story
2s4x0 is offline   Reply With Quote
Old 10-01-2007, 08:02 PM   #2
2s4x0
2s4x0's Avatar
now i have oil burning on my mani or turbo cant tell where its coming from... its in the space between block and outside of mani. if that makes sense
Old 10-01-2007, 08:08 PM   #3
dirtyafrican
dirtyafrican is an unknown quantity at this point
so... you have no leaks you say? you have a cracked manifold or gasket.
dirtyafrican is offline   Reply With Quote
Old 10-01-2007, 08:18 PM   #4
trmn8r
trmn8r's Avatar
trmn8r is an unknown quantity at this point
id first check the throttle position sensor. it should be at .5 volts. obviously theres an a/f issue. check timing you should be at 15 deg btdc. oh and one thing, you might of checked already, make sure the coil packs are fully connected to where you hear the click. let me know how it goes from there
oh yah! its el nismo
trmn8r is offline   Reply With Quote
Old 10-02-2007, 03:22 PM   #5
2s4x0
2s4x0's Avatar
bump. bump. bump,
