Old 10-07-2007, 06:59 PM   #1
DDSR240
DDSR240's Avatar
DDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond repute
s13 Both my s13s are screwed
As 4 my ka no power to fuel pump or starter but both work and I keep getting an ecu code flash 1...2...3...4..5 and it just keeps repeating. And if any body knows what sends the fire signal to the coil packs on a sr20det please let me know im only getting spark to one cylinder.
DDSR240 is offline   Reply With Quote
Old 10-07-2007, 11:02 PM   #2
DDSR240
DDSR240's Avatar
any body home
Old 10-07-2007, 11:04 PM   #3
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
coil packs------igniter
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 10-08-2007, 12:00 AM   #4
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
No power to starter or fuel pump indicates problem in the ignition switch circuit
RedtopTech is offline   Reply With Quote
Old 10-08-2007, 08:04 AM   #5
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
Check your fuses
SDS13COUPE is offline   Reply With Quote
Old 10-08-2007, 08:16 AM   #6
boycelaforest707
boycelaforest707's Avatar
boycelaforest707 is a well-known jackass
code 1-2-3-4-5 means your not in diagnostic mode, it is asking you to change modes. This is a SOHC right?
Spark on SR20 sent by ECU to IGNITOR CHIP to COIL PACK
1991 240sx Hatchback 5spd
boycelaforest707 is offline   Reply With Quote
Old 10-08-2007, 08:40 AM   #7
DDSR240
DDSR240's Avatar
can I use a q45 igniter chip with aem standalonea BASE MAP?
Old 10-08-2007, 09:16 AM   #8
240sx_LE
240sx_LE has made poor choices240sx_LE has made poor choices240sx_LE has made poor choices240sx_LE has made poor choices240sx_LE has made poor choices240sx_LE has made poor choices
you and me both buddy... are screwed. well, atleast you still have a possibly running motor anyway.
240sx_LE is offline   Reply With Quote
Old 10-08-2007, 10:52 AM   #9
SDS13COUPE
SDS13COUPE's Avatar
I'm running a Q45 ignitor chip. All you need is the connectors with the harness so you can wire it up. I'm not sure about the aem base map.
Old 10-08-2007, 03:28 PM   #10
DDSR240
DDSR240's Avatar
finnaly got it running but the auto trans will not go in to the final gear it revs at like 4000 doing 65 wtf is going on.
Old 10-08-2007, 03:30 PM   #11
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
Sounds like overdrive is off... either the button is not pressed, or your auto tranny control unit is bad (or the wiring somewhere in that circuit is bad).
bew bews!
brokeAs240sx is offline   Reply With Quote
