Old 10-09-2007, 04:28 PM   #1
s13bm
s13bm is making his/her stupidity well-knowns13bm is making his/her stupidity well-knowns13bm is making his/her stupidity well-knowns13bm is making his/her stupidity well-known
running good then it wouldnt start
my friend has a 93 ka24de it was runnig really strong then went to get something to eat and all it diid was crank over and wouldnt start like no spark
s13bm is offline   Reply With Quote
Old 10-09-2007, 04:48 PM   #2
GSXRJJordan
GSXRJJordan's Avatar
Check things like fuses first. Most likely something's shorted and blown a fuse.
Then you need to do normal things, like pull a spark plug, reconnect it, ground the body, and check for a spark when you start the car.
Then you need to get familiar with the [SEARCH] button
Old 10-09-2007, 04:57 PM   #3
s13bm
ok thank u for the help
Old 10-09-2007, 05:44 PM   #4
lovdrifting52
lovdrifting52's Avatar
Trader Rating: (34)
lovdrifting52 is making a name for him/her selflovdrifting52 is making a name for him/her self
Feedback Score: 34 reviews
yeah check your ignition fuses first, i had a similar problem and it ended up being the starter but check that everything else first or just hit your starter as your turning the key
lovdrifting52 is offline   Reply With Quote
Old 10-09-2007, 10:52 PM   #5
PIERCEMAN
PIERCEMAN is an unknown quantity at this point
I had this issue with my ka and it was the fuel pump, some people have also seen this with a old/dirty fuel filter
MAtt
PIERCEMAN is offline   Reply With Quote
Old 10-10-2007, 08:19 PM   #6
s13rookie
s13rookie's Avatar
s13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant future
Send a message via AIM to s13rookie
As was mentioned above, give the starter a little tap with a hammer in case it has a bad spot. Do you smell anything when trying to start? If the car had sat for a while, whatever crap in the tanks/line would have ended up in the filter when it was running for a short time. Start with that- its like $8 and ten minutes of time
Good Luck
Ive spent most of my money on cars and women...the rest i wasted
s13rookie is offline   Reply With Quote
