Old 10-23-2007, 09:06 PM   #1
BrandonS13
BrandonS13 is an unknown quantity at this point
Need help with s14 swap
I've searched pages and pages of info
could anyone supply me with a link to a 1995 KA motor into S13 info?
as in do i need a s14 harness to do this ??/
thanks in advance guys
BrandonS13 is offline   Reply With Quote
Old 10-23-2007, 09:10 PM   #2
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
no. you can swap intake manifolds with your s13 if your s13 was a dual overhead ka (ka24de)
if your s13 didn't have a dohc and you don't have an s14 wiring harness, then what DO you have?? lol and then i'll tell you what to do
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 10-23-2007, 09:13 PM   #3
BrandonS13
i bought a fixer upper to flip..
it came with the 95 motor, and a BUTCHED harness like a serious JOKE
half the sensors arent connected etc..
is there at least ONE specific thing i can tell on this KADE to assure it is even a 95+ cuz if it isnt then i obviously wont have this problem...
thanks
Old 10-23-2007, 09:31 PM   #4
Z U L8R
Z U L8R's Avatar
hrm.....it's been a while since i did a ka..... i believe the coolant temp sensor will have a plug on it that you squeeze to disconnect if it is an s14. if it's an s13 DE then it should have the ole school slide on joint with the paper clip guy that you always lose and never put back on it hahaha
Old 10-23-2007, 09:53 PM   #5
BrandonS13
im going to run out to the garage and chekc it out..
does anyone else have any destinctive facts to know the year of the motor?
regardless could i possibly get a link to the info needed to do this swap;
s14 ka into s13a chassis? thanks
Old 10-23-2007, 10:07 PM   #6
BrandonS13
ok it is a s14 engine i noticed the dizzy has 2 plugs vs. 1 on s13 engine
as well as the coolant temp sensor doesnt have the clip and is not on the neck to the rad outlet hose.
please help with info for this swap thanks alot
Old 10-23-2007, 10:31 PM   #7
JRwerks
JRwerks's Avatar
Trader Rating: (55)
JRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of light
Feedback Score: 55 reviews
S14motor-S13 hatch
If its a 95+then itll have 2bolts ontop of the valve cover and if its a 91-94 i believe then it'll have 3bolts on top of the valve cover so thats how u can tell if its a s14 or s13 motor and all u need is a s13 harness,s13ecu,s13intake manifold... unless u got the s14 harness and everything wired up for the s13 i have a 96'ka24de witih 91intake manifold,91ecu,and 91 harness works great...
JRwerks is offline   Reply With Quote
Old 10-24-2007, 07:20 AM   #8
projectRDM
projectRDM's Avatar
The 95 will have the same CTS, TPS, and O2 as an S13 DOHC. Only 96+ KAs use different sensors.
Use a 91-94 harness and ECU.
And search, we've discussed this to death a million times.
FORMERLY R240NA
Old 10-24-2007, 09:43 PM   #9
Z U L8R
Z U L8R's Avatar
use your s13's intake manifold and be done with it.
