Old 10-23-2007, 02:31 AM   #1
jays_240
jays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choices
18x9.5 +20 all around
will they fit a s14 with z32 in the front...? and if they do...? will the fender clear the rims...? or are they gonna rub each other...? thanks alot...!
*20mm front fender
*just bought tanabe coilover...will put them on before buying wheels
*i have tanabe springs/kyb shocks on the car now
jays_240 is offline   Reply With Quote
Old 10-23-2007, 02:55 AM   #2
CSil80
Banned from the Marketplace
CSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfection
Search, it's fun
http://www.zilvia.net/f/showthread.php?t=82859
CSil80 is offline   Reply With Quote
Old 10-23-2007, 02:56 AM   #3
EJ253
EJ253's Avatar
EJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfection
Send a message via AIM to EJ253 Send a message via MSN to EJ253
what camber are you running?
stock suspension?
The gap between MORE and ENOUGH never closes.
DriftUtah | UtahNissans | MySpace | I <3 Drifting. Keep it Real.
Secret Society
EJ253 is offline   Reply With Quote
Old 10-23-2007, 04:25 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Offset got abso-fucking-lutely nothing to do with brake clearance...
CLICK HERE!!!
Old 10-23-2007, 04:46 PM   #5
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
I first had a 10mm to make it a +10 to clear my coilovers. Then i added a 5mm spacer so it would line up w/ the 20mm ait fender & 225/40/18 front tires and -3 camber.
you can leave the rears w/ the +20 and run 245/40/18 w/ a slight pull on your rear quarter panels w/ a -2 camber
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 10-23-2007, 04:56 PM   #6
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I have 17x9.5 +15 with 235/40 with -2 camber in the front. About one finger gap with pull.
Jung918 is offline   Reply With Quote
Old 10-23-2007, 04:59 PM   #7
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Originally Posted by swayray View Post
I first had a 10mm to make it a +10 to clear my coilovers. Then i added a 5mm spacer so it would line up w/ the 20mm ait fender & 225/40/18 front tires.
you can leave the rears w/ the +20 and run 245/40/18 w/ a slight pull on your rear quarter panels...
The only car I've ever seen that looks GOOD with Sportmax's
Old 10-23-2007, 05:00 PM   #8
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
what face wheel? what camber? etc etc etc what size tire... this is going nowhere
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 10-24-2007, 10:10 AM   #9
jays_240
Just Wondering Did U Change The Studs....? For Longer Ones.....or Did U Leave It Just The Way It Was...because Of The Spacer
Old 10-24-2007, 01:54 PM   #10
pbcstylez
ray mentioned he had a 10mm spacer + 5mm spacer = 15mm, i believe thats about as much stud as you show on the OEM studs therefore I am assuming he went either of 2 routes:
1.) extended studs Nismo, peak performance etc
2.) 15mm bolt on spacer affair
either or works efficiently, price both options out, i think they're relatively the same
personally id run the extended studs this way u can change your offset with the spacers on the fly
