Old 11-08-2007, 01:27 AM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Steering angle spacers- W T F !?!?! How do they work and why i didn't run them.
I went to install steering angle spacers today (s14 chassis, z32 rods, spl ends) but i ended up backing out and not using them. With the spacers on i could only get THREE FULL THREADS contact with the steering rack. I can't possibly phathom how this is safe.. Do some of you actually run such minimal thread grab or is there a secret i dont know?
Also, my old shop teacher, a mechanic, and myself couldn't figure out how the hell that spacer helps steering angle. The way we see it, the spacer simply makes you shorten the tie rod the exact same width of the spacer...In the end the length from the rack to the rod end is identical... Can someone explain how that actually increases angle?
gotta240 is offline   Reply With Quote
Old 11-08-2007, 01:36 AM   #2
EJ253
EJ253's Avatar
EJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfection
Send a message via AIM to EJ253 Send a message via MSN to EJ253
it decreases the length of the pivoting point (balljoint in the inner tierod)
when this pivoting point is closer to the wheel assembly, the angle of the steering wheel in comparison to the wheels themselves becomes exaggerated
you need to turn the steering wheel less for the wheels themselves to move the same amount
so at full lock, the wheels have turned further out
The gap between MORE and ENOUGH never closes.
DriftUtah | UtahNissans | MySpace | I <3 Drifting. Keep it Real.
Secret Society
EJ253 is offline   Reply With Quote
Old 11-08-2007, 01:39 AM   #3
Dousan_PG
Dousan_PG's Avatar
wow time for anew shop teacher w/ a brain
and secondly
should ge tmore then 3 threads
all mine get a lot of turns
but i use all s14 jazz and s13 stuff
so ....yeah.
Aaron
Pink GodziRa
Old 11-08-2007, 01:53 AM   #4
Skullavera
Skullavera's Avatar
Skullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfection
Send a message via AIM to Skullavera
Oh shit did I misread something?
My mistake.
Reviews/Feedback!
Skullavera is offline   Reply With Quote
Old 11-08-2007, 01:56 AM   #5
S13Leprechaun
S13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant future
lol... maaaan you dont need these anyway... its not that much diff...
ps. whats up with ur buddy coming for the truck? stilll on? lmk man. free bump!
thurs. knights.
S13Leprechaun is offline   Reply With Quote
Old 11-08-2007, 02:00 AM   #6
Dousan_PG
Dousan_PG's Avatar
apparently you don't use them
or u have no cool angle
im actually getting some modded spindles shortly
gonna test those puppies out
Aaron
Pink GodziRa
Old 11-08-2007, 02:04 AM   #7
D1GP
D1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the rough
Originally Posted by Skullavera View Post
WTF?^^^^^
The spacers correct Bumpsteer. They make your tie rods level to the ground giving you less steering angle change (bumpsteer) while the suspension is being compressed.
Where exactly did you install the spacers? For some reason I think you installed them wrong. They go on the outer tie rod end, not the inner one. This is quoted straight from SPL themselves:
On cars that are lowered significantly, the stock outer tie rod ends can bind and snap or bend the tie rods. Our outer tie rod ends have more articulation angle than stock tie rod ends, and have adjustable spacers to move the outer tie rod end lower to eliminate binding.
Our unique design allows for easy bumpsteer adjustment in 0.3" increments, allowing for up to a +1" shift of the pivot point from the stock location. This offers much greater adjustment than any other aftermarket outer tie rod ends. The bumpsteer spacers are integral to the design and reinforce the shank under bending loads. Spacers are CNC machined from 2024 aircraft aluminum alloy (also known as Super Duralumin), a much stronger (and much more expensive) aluminum than the more common 6061, this expensive alloy is lightweight yet has almost the same tensile strength as steel.
OP is talking about the steering angle spacers not the bumpsteer spacers.
http://www.splparts.com/doc/SPLTieRodEnd/default.htm
Check out this diagram. You need to use the silver ones which you need to purchase separately from SPL Parts for 10 bucks. If you are using the black bumpsteer spacers, then no wonder you aint catching threads for shit. You will also need to get rid of the stock locking plates and use LockTite on the threads. All of which are explained the the link above.
D1GP is offline   Reply With Quote
Old 11-08-2007, 02:10 AM   #8
tt99ol
tt99ol's Avatar
tt99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond repute
Send a message via AIM to tt99ol
hey Aaron let me know how those spindles work out for you because i was thinking about doing the same thing, your just shortening them right?
tt99ol is offline   Reply With Quote
Old 11-08-2007, 02:13 AM   #9
EJ253
EJ253's Avatar
why does TEIN include the angle spacers when you buy the inner tie rod then?
http://www.frsport.com/Tein_TRS01_N2...14_p_1024.html
not the outter tie rod
http://www.frsport.com/Tein_TRS01_N2...14_p_1025.html
please help me out.
where on this diagram would the angle spacers be? (sorry the pic isnt bigger)
because i was under the impression that theyre inbetween the steering rack and the inner tie rod (located inside the dust boot)
Secret Society
Old 11-08-2007, 02:14 AM   #10
Skullavera
Skullavera's Avatar
Ahh....my mistake. I guess I should be getting to bed and getting some rest!
Reviews/Feedback!
Old 11-08-2007, 02:14 AM   #11
D1GP
please help me out.
They are indeed attached to the inner tie rod bro, he just got the shit confused with the bumpsteer spacers which do go on the outter tie rods.
Old 11-08-2007, 02:20 AM   #12
Skullavera
Skullavera's Avatar
Correct Right There ^^^
Reviews/Feedback!
Old 11-08-2007, 02:21 AM   #13
D1GP
appreciate the rep. go get yourself some sleep now .
Old 11-08-2007, 02:24 AM   #14
EJ253
EJ253's Avatar
glad we got that figured out.
back to the topic at hand.
why your only getting 3 threads.
are the Z32 tie rod's threads shorter than S chassis'?
how long are the angle spacers?
a possible solution might be to shave the spacer down on a grinder until you feel it has a safe amount of threads.
the spacers do help tho, so they are worth the trouble IMO
Secret Society
Old 11-08-2007, 02:28 AM   #15
S13Leprechaun
wow just the spacers make that much of a difference huh?? hmmm.. how big are the spacers? are there diff sizes are is it a one size thing?
thurs. knights.
Old 11-08-2007, 02:32 AM   #16
EJ253
EJ253's Avatar
well, you could use a washer if you really wanted. it wouldnt do much of anything tho
anywhere from 0.5cm - 2cm would be a decent sized spacer
altho i'd rather be on the bigger side
Secret Society
Old 11-08-2007, 02:41 AM   #17
S13Leprechaun
hmmm.... interesting... how do you install it?? nvm ill just search.. its gotta be here somewhere...
thurs. knights.
Old 11-08-2007, 02:42 AM   #18
D1GP
Dude just check out the link in post 7.
Old 11-08-2007, 02:44 AM   #19
S13Leprechaun
good idea i missed that... lol.. geez i need to go to bed... ahhh!
thurs. knights.
Old 11-08-2007, 08:43 AM   #20
attracted
attracted's Avatar
attracted is making a name for him/her selfattracted is making a name for him/her self
for the guy that wanted to try the modified hub...let me know how it works out cuz down here in montreal we tried it out....you get crazy crazy angle but the steerign becomes so much stiffer and for some reason we lost alot of the feedback on the steering....reminded me a bit when we installed a steering shaft reducer...it was like there was no feedback...pls let me know
attracted is offline   Reply With Quote
Old 11-08-2007, 10:16 AM   #21
Dousan_PG
Dousan_PG's Avatar
im getting them from a friends shop in japan
they make them
i have to ems the money over and then they send the part
ugh its such a fucking hassle
Aaron
Pink GodziRa
Old 11-08-2007, 10:30 AM   #22
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
just get the Tein ones, I did, and the inner rod has an extended stud to allow for the space the spacers take up.
And for all the nay sayers, it’s worth it and will be noticeable.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 11-08-2007, 10:35 AM   #23
Shaminii
Shaminii's Avatar
Shaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really nice
Send a message via AIM to Shaminii
Teins have longer studs to allow more threads once the spacer is in. And yes, they are the great.
Shaminii is offline   Reply With Quote
Old 11-08-2007, 10:48 AM   #24
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
Probably a dumb question, but how much of a difference would these make in turning radius? My old hatch could literally turn around in the street just by doing a u turn, didnt even come close to hitting the curb. My S13 now can't even come close to doing that, I have to do a 3 point turn. I always wondered why that was.
ryguy is offline   Reply With Quote
Old 11-08-2007, 10:55 AM   #25
ewuzh
ewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of lightewuzh is a glorious beacon of light
I didn't have any problems with not having enough threads. I have the Tein inners and outers and love em.
When I'm turning and I think I should be at full lock already...it just keeps on turning!!! lol the extra angle actually saved me from spinning out a few times at the track.
ewuzh is offline   Reply With Quote
Old 11-08-2007, 11:23 AM   #26
Wiisass
Wiisass's Avatar
Wiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond repute
Send a message via AIM to Wiisass
Please don't say stuff like that. I think the tein spacers are 6mm thick and I wouldn't go much more than that on stock size inner tie rods. 2cm or 20mm would take up pretty much all the threads on the inner tie rod.
You have to put a little more thought into it than just shortening the steering arm on the spindle. Steering geometry can get complicated and there are other factors that will contribute to how the steering feels. And you have ackerman to consider and all that other fun stuff. But even just shortening the arm is going to increase the steering effort.
Tim
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Wiisass is offline   Reply With Quote
