Old 11-18-2007, 10:48 AM   #1
CAPoweredS14
CAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really nice
Blitz FATT, everything stays on but motor WTF?
So I spent the last couple nights doing some searching and even PM'ing a few people across different forums and I haven't found the topic made yet. Here it goes:
SO the timer is wired up according to that 240sx.org write up and everything is set correctly. The only problem is that when the key is turned off and the turbo timer steps in to do its job all it keeps on is radio. So if you were to turn your key to the "on" position and have radio come on, and fuel pump prime, thats where the timer keeps it. It just doesn't keep the motor running. Now I let it go through its cycle and after 30 secs it turns off just like it should. Any help? I have a 95 S14 with a CA18DET. Doubt motor makes a diff but just puttin it out there. Also base model.
Cliff Notes: 1995 Base S14/CA18DET. Turbo timer doesn't keep motor on just accessories..
CAPoweredS14 is offline   Reply With Quote
Old 11-18-2007, 11:27 AM   #2
onesicklambo
onesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant future
you prob only tapped into ACC on the FATT, is there an IGN wire too? (prob) you need to be powering both those while the key turns off
onesicklambo is offline   Reply With Quote
Old 11-18-2007, 12:02 PM   #3
CAPoweredS14
Ok found the problem... I have a 1995 and there is a difference with 1996 models. Let it be known that there is one wire difference and it was wired as a 95 should be but the harness in the car is 96 spec. So FYI to any other person. I will try to find original thread and post it in there for future users.. Thanks onesicklambo for your input..
