![]() Join Date: Aug 2005
Just wanted to make sure I have my info correct(Koni suspension)
I am wanting to use the Koni Yellow inserts/Ground Control setup on my S14. Just wanting to make sure know of everything I will need.
-Koni yellow inserts (I need the part number) -ground control coilovers with my choice of springs -some sort of pillowball upper mounts -And I need my stock strut housings front and rear, correct? How low will I be able to go with this setup? Can I go lower by mounting the inserts lower in the strut housing? (I know this setup isn't for slamming the car, that's not what I'm looking for, just seeing if it's a possibility). I have never experienced this type of suspension (using the stock strut housing/aftermarket struts). Basically I am wanting the bottom line on everything I will need and what kind of height adjustability I will have. Thanks! ![]() |
![]() Join Date: Mar 2002
i had koni/GC's on my maxima and it dropped it more than 3". Could have gone even more
Handle nice for a bigger car
Ive spent most of my money on cars and women...the rest i wasted |
The rear is a bolt up shock and the front you will need to use your stock housing.
In order to do the front the "right" way you will need someone to weld a ring around it and remove the factory spring seat. (see 10 page ground control thread for pics)
www.nissanroadracing.com |
