Integra LS Greddy Turbo Kit problem
So I understand this isn't exactly a Honda / Acura forum and i've searched over and over and tried a bajillion things...
So heres the problem: The car struggles to idle It seems to warm up fine and such and idle @ normal 750. When I tap the gas or rev the motor and let go, it falls all the way down to 100rpm and struggles to climb back to normal ??? I get CEL of random misfiring What I have done: -No vaccuum leaks -New fuel filter -Not the O2 sensors -Distributor and spark wires are A OK -Spark plugs look... slightly green? shade of white?(plugs are colder) -Compression test OK! I'm stumped ![]() -is it the rc injectors? -Low fuel pressure? -me? Any help will do. Thanks! |
the bov recirculates in to the T w/ the throttle body / actuator etc. Heres the weird thing.. the Greddy Type RS doesn't seem to "blow off" ever, and its set at softttest. could it be a bad... bov???????? |
check your idle air control valve...it might be dirty
hondas run off map sensors therefor u dnt need to recirculate the blowoff most hondas wont open the blowoff if u dnt move...u have to drive the car...or do a full throttle on stand still....then again i suggestt u get it tuned b4 anything |
![]() Join Date: Dec 2004
Trader Rating: (58)
Whats it tuned for? Management? Etc etc. This isn't going to work at all with a stock ECU unless you have Hondata/Chrome/Neptune similar helping you out....
#7 | |
I have a freind who is desperately in need of an S13 rolling chassis. Engine is not neccesary ![]() |
![]() Join Date: Feb 2007
I installed a greddy kit on my friends D series civic. We ran it off the SAFC. After installing the kit with a set of 440's RC injectors. Its would idle badly at 700-800 rpms. Then all of a sudden die down to 400 and barely kept running. He got Uberdata and then everything was solved.
#14 |
WHAT RC INJECTORS AND COMPUTER are you running? also FMU? sounds to me like your injectors are to big and freakin out the o2 and stock computer, if thats what you are running? OR IS IT A NEW KIT FROM GRD?
#15 |
the RC 310 injectors came w/ the Greddy Kit.
It is running off of the Greddy Blue Box unit. Not emanage. **Heres something I found out. One week prior to his install, he had installed the ECU and injectors 1st. The car ran super duper rich for one week. Could this have fouled up his EGR and stuff? When he began to install the turbo kit a week later his stock injectors were pitch black nasty. A few ecu codes before the new plugs and kit installation were he says: BARO sensor, EGR, and random misfiring. After installation of the new spark plugs and turbo kit the BARO sensor and EGR had went off after resetting the cu and it only through the Random misfire and shatty idle. |
#16 |
This might be a stupid question but are you running a "missing link" for your map sensor?
That can cause the car to trip out as well because the map might be reading wrong or incorrect information. Good luck BTW you dont need fuel management to get the car to run and operate normally, Since you are running the greddy blue box this may be a problem because these units tend to go bad from time to time. If you have stock ECU try plugging that in for testing only. If the car idles and revs fine then you'll know its your bluebox mis-functioning.(BUT MAKE SURE YOU HAVE A MISSING LINK) I'm taking that you have an OBD-II system? 96+? Honda's dont really have that much problems when you run boost, just make sure everything is in working order. There's only one main source for vacuum and that comes right off the intake manifold and goes directly to the FPR.
#18 |
![]() Join Date: Nov 2004
Why don't you try www.honda-tech.com?
#19 | |
Like Me on FaceBook ![]() |
#21 |
![]() Join Date: Feb 2003
I put the greddy kit on my 97 ex and used the blue box at first and it did the same thing, so i dumped it for a vortech fmu 10:1 disk, missing link and an safc. worked tit. you shoulda sprnt the money and got a peak boost setup imo. good luck and check on honda-tech in the forced induction section
#22 |
yeah.. try hondata/chrome.. if you run a fmu you need to use a missing link on a honda.. hondata/chrome eliminates that.. i belief the stock map sensor can handle up to 10 psi of boost.. what year is the integra? obd 0 1 or 2? are you getting fuel ? can you hear the fuel pump prime when you turn off and on?
#24 | ||||||||
Trader Rating: (58)
As you said, With 310 injectors, he wont' need that link.
#26 |
![]() Join Date: Jan 2005
check your timing (at the blet- align tdc visually) might have skipped a tooth when you ran pig rich... dont get a FMU thats asking for it to blow.... just chip it'll cost u 200 and thats including a eprom burner...
Zzzz |
