Old 11-19-2007, 07:30 AM   #1
zeroskater1028
zeroskater1028's Avatar
zeroskater1028 is just really nicezeroskater1028 is just really nicezeroskater1028 is just really nicezeroskater1028 is just really nicezeroskater1028 is just really nicezeroskater1028 is just really nicezeroskater1028 is just really nicezeroskater1028 is just really nicezeroskater1028 is just really nicezeroskater1028 is just really nice
Send a message via AIM to zeroskater1028
Car doesnt rev past 3000 rpm
Ok so this is my problem. Today in the morning i was on my way to work. I was sitting in the car and it just stalled on me. 1st time it does this. So i thought that was weird and thought nothing of it. So i finally get rolling and im up to 3000 rpm's and the car just doesnt go past that. Feels as if it was being over rev'd but at 3000 rpm's. Anyone have any ideas. Going to a shop so they could check it out later on. Thanx
zeroskater1028 is offline
Old 11-19-2007, 07:40 AM   #2
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
SR? KA? Help us out here. This question has been asked at least 1000 times as well, try a search.
If it's an SR, or a KA-T, check for boost leaks. See if an intercooler hose popped off. Check your MAF sensor, see if the plug came loose, or if you have vacuum leaks anywhere.
My seller review thread
SHIFT_*grind* is offline
Old 11-19-2007, 07:46 AM   #3
zeroskater1028
SR sorry about that. Ya its the SR though. kool thanx will check right now. Be back with my conclusion.
Old 11-19-2007, 07:51 AM   #4
-L(-.O)
-L(-.O)'s Avatar
-L(-.O) is on a distinguished road
yeah sounds like maf. but if you cant boos past 5lbs then you might have a serious boost leak. with maf unplugged you can feel it have like a rev limit around 3~4000. boost leak is just hard getting past 3~4000.
-L(-.O) is offline
Old 11-19-2007, 07:53 AM   #5
zeroskater1028
Ya i just came back from checking the hoses and they were fine so i unplugged the MAF and plugged it back in while the car was still on and everythings fine now. Took it for a test run and everything. Thanx 4 the help guys.
