Old 02-04-2005, 05:36 PM   #1
DTS
DTS is a well-known jackass
Serious problem with my subframe (Pics)
So im trying to install my SPL parts aluminum subframe spacers and i do the passanger side no problem, on to the drivers side, and the front subframe mount wont drop down enough for me to slide the spacer in
so i look at it and the actual bolt on the end of the peg is connected to the rubber bushing but the passanger side is fine!
As you can see in this pic this is the passanger side which is fine and has a rubber ring and has a bolt that drops threw the ring
on the drivers side the bolt is actually connected solidly to the bushing not allowing the subframe to drop!!
what the hell is going on guy!!
will it affect my performance if i only use the bottom half of the spacers for the front mount the back is fine and the passanger!
please help
DTS is offline   Reply With Quote
Old 02-04-2005, 06:00 PM   #2
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
you cant pry it loose. When I did my subframe spacers I took a pry bar and stuck it between the car and the sumframe and had a friend jump on it (not really) My wernt that bad, but kinda fused (dont know why) but after a while I was ably to pop em loose. Another thing you can try is to take off the other corrner of the subframe on the same side and give yourself more leverage. It should pop loose. Keep us updated.
DJPimpFlex is offline   Reply With Quote
Old 02-04-2005, 06:13 PM   #3
DTS
i actually unbolted all of the bolts for the subframe so it was hanging on that bolt and jacked the subframe and then let it drop quickly and it was just flexing on the bushing its like the collar is actually connected to the stud.
i havent tried a pry bar but i will, shouldnt the collars be the same? the passanger side is noraml and has a ring of clear space so it can easily slide in and out and this one has 0 space it looks welded or connected
bwt the car is a 93 s13
Old 02-04-2005, 07:17 PM   #4
turtl631
turtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond repute
Good luck! I did the full aluminum bushigns on my s14. The 2 front subframe bushings actually had the inner metal race fused to the post. THe subframe came off with the race still attached to the post! Sucked ass
turtl631 is offline   Reply With Quote
Old 02-04-2005, 08:05 PM   #5
1101
1101 is an unknown quantity at this point
It's rusted on there, try soaking it in pb blaster or WD-40, Then prying at it with a crow bar or something. It apears it's not the only rusted thing on the car.
My car barly had that much rust on it, the first thing I did was rip the rear end apart, glass bead all the parts, pro-40 (or something like that), prime, paint. Plus pressed in new nismo subframe bushings.( Aluminum ones werent out at the time.)
1101 is offline   Reply With Quote
Old 02-04-2005, 09:37 PM   #6
SimpleSexy180
wow you got a lot of rust...
SimpleSexy180 is offline   Reply With Quote
Old 02-04-2005, 10:07 PM   #7
thx247
thx247 is an unknown quantity at this point
BFH time...fixes everything.
Finally down to 1 car again. Thank god.
thx247 is offline   Reply With Quote
Old 02-05-2005, 10:58 AM   #8
DTS
I live in canada, finding a rustless car is literly impossible.
my car is one of the cleanest ones up here, but still rusty compaired to you guys down in the southern states
damn road salt and winters!
Old 02-05-2005, 11:15 AM   #9
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
why the hell do you people post the exact same threads in other forums? im pretty sure frresh alloy answered your Q's...
MakotoS13 is offline   Reply With Quote
