![]() Join Date: Jan 2013
CA18 Gurus Help! Need to identify a valve
So I'm about to drop my ca18 in this weekend and am mostly done prepping the engine but I can't seem to figure out where this green valve on the block connects to. At first I thought it was part of the pcv system but after tracing the lines it seems that is not the case (although if the pcv system is as convoluted as the butterfly setup on this motor I could very well be missing something). Does anyone know what this valve is and where it connects too? I can't seem to find anything about it online and I have been unable to locate any reference to it in the fsm. I have a European fsm so I'm thinking it might be a Japan only thing since the European Ca engines have quite a few differences. Pics are below, any help would be greatly appreciated!
![]() ![]() ![]() So you can get a idea of where its located in relation to the intake side of the motor ![]() The hose that runs directly below the valve is part of the pcv system that is connected to the rear of the valve cover and runs to the oil filter housing. I don't see any place for it to T into the system or connect to the manifold, which has me thinking that it is not pcv related but as I said before I could be wrong... |
![]() Join Date: Sep 2011
![]() Feedback Score: 8 reviews
so it deals with oil or vaccum or both
that looks like antifreeze under it my guess would be turbo water line feed.cant be return because thats located on the hot side that my .2 |
That was one of my first thoughts as well but the water line to feed the turbo comes from a port on top of the intake manifold. It looks like coolant in the picture but seems to actually be some sort of clear glue or sealant that is around the valve (it doesn't look green in person, I think the reflection from the camera flash gave it that tint in the picture). I'm pretty sure it deals with vacuum or oil as well but I can't for the life of me figure out where it goes. This engine came from a bone stock 180 with 72,000kms so I'm fairly certain that its from the factory and not part of a modification that someone made but I could be wrong.
