Old 12-24-2007, 07:00 PM   #1
sr20 driver
sr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choices
sr20 catchcan
can anybody tell me wats going on plz, im weaking oil from the tube on the valve cover were the air breather goes any one have this problem b4?
sr20 driver is offline   Reply With Quote
Old 12-24-2007, 07:02 PM   #2
nissanguy13
nissanguy13's Avatar
nissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant future
valve cover gasket, cracked valve cover?, clean the area off and start your engine or drive it for a few blocks and try to see exactly where it's coming from.
Originally Posted by unicoladron;
dick, i had like 4 posi reps in a row and you ruined it
nissanguy13 is offline   Reply With Quote
Old 12-25-2007, 03:53 PM   #3
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
i've discovered the same issue on my engine, but it turned out to be a crack in th hose. you might inspect you hose.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 12-26-2007, 03:09 PM   #4
sr20 driver
white smoke is coming out of were the air breather goes any other clues will be very helpful thx
Old 12-26-2007, 05:48 PM   #5
tig_tech
tig_tech's Avatar
Trader Rating: (25)
tig_tech is on a distinguished road
Feedback Score: 25 reviews
Like mentioned earlier, check for a cracked hose because the rubber gets brittle due to the heat from the manifold or check to see if the fitting the hose connects to is loose. Is the white smoke coming out at idle or on load? That smoke is only just blow-by gases.
tig_tech is offline   Reply With Quote
Old 12-26-2007, 05:56 PM   #6
sr20 driver
its comin by idle. oil coming out by load. it never smoked from there
Old 12-26-2007, 05:58 PM   #7
burnsauto
burnsauto's Avatar
please dont double post. you've already asked about the smoking/oil problem in another thread. leave it to one.
Old 12-26-2007, 10:26 PM   #8
nissanguy13
the engine's broken throw it away, or give it to me and I'll make it work
