Old 01-06-2008, 09:18 AM   #1
gippy87
gippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-known
Car decided its never going to turn off
I justr swapped my car to sr20 and it runs and drives great with no problems untill this morning. I tried to turn the car off and it keeps running. I can literally drive the car around the block without the key if it didnt have steering lock. It doesnt eventually die or anythign it just keeps running untill i stall it. And all the gauge cluster lights stay lit red when i stall it and take key out. Any idea what would make the car continue to run?
gippy87 is offline   Reply With Quote
Old 01-06-2008, 03:22 PM   #2
gippy87
Nobody
Old 01-06-2008, 03:27 PM   #3
mrpeepers
mrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nice
I had the same problem with my s13 KA. I had an alarm system installed at the time and when i took it to the stealership they said it fried a circuit. Then again they dont call it a stealership for nothing, repair was $1200
mrpeepers is offline   Reply With Quote
Old 01-06-2008, 04:00 PM   #4
rhs13
rhs13's Avatar
rhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant future
Send a message via AIM to rhs13 Send a message via Yahoo to rhs13
when stuff like this happens to me, i use it as an excuse to install more switches.
-fuel cut off
-battery kill
cuz i dont give a fukk. that's why.
rhs13 is offline   Reply With Quote
Old 01-06-2008, 05:34 PM   #5
gippy87
lol rhs i was thinking about a kill switc for the battery cause really i dot have any issues other then it not turning off.
Old 01-06-2008, 06:12 PM   #6
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
super turbo timer :ghey:
slow40sx is offline   Reply With Quote
Old 01-06-2008, 07:10 PM   #7
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
yea sounds like your alarm is looping the power to the turbo timer and vise versa.
projekt_s13 is offline   Reply With Quote
Old 01-06-2008, 07:27 PM   #8
weagle
weagle's Avatar
weagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant future
I was going to say if you had a turbo timer, maybe it didn't have enough power to turn itself off. I know it sounds crazy but I had it happen to me. I also live in wisconsin and it was the dead of winter. Turned the car on just to let it idle for that week and I went to go turn it off and the turbo timer wouldn't turn off. I ended up disconnecting the battery.
weagle is offline   Reply With Quote
Old 01-06-2008, 11:18 PM   #9
gippy87
Update: so the engine turns off when i turn the key to off now but ecu and red dash lights still stay on then after driivng somemore it was turning off normal again but after just gogin outside seems it has turned the ecu and dash back on. I know ecu is on cause of the red led.
Old 01-07-2008, 12:23 AM   #10
rhs13
rhs13's Avatar
afterthought
i just remembered that i had a similar problem with my radio staying on, etc. if your car is lowered enough and youve been driving around like that for a while, chances are, your driver side front wheel ate through the wire loom that runs along the top of the wheel well. if enough wires are exposed you might get constant power to certain circuits, or the car will shut off in the middle of a high speed right turn (which happened, leaving me in the middle of a mountain road with no hazard lights).
so check it out. you can easily remove the fender and relocate the wire loom using big zip ties.
Old 01-07-2008, 11:09 AM   #11
gippy87
rhs idk why no one has ever mentioned that before but thank you. That is most deffinitly why my headlight no longer go down the wires are all chewed up. Not sure if fixing the wires will make my car turn off right cause i dont think theres anythignt o do with ignition on that side but at least somthign will be fixed.
Old 01-07-2008, 11:10 PM   #12
gippy87
Update: When i pull the alternator fuse the dash lights and ecu turn off. Tommorrow im uninstalling the alarm and reparing the harness well see what happens.
Old 01-08-2008, 03:50 PM   #13
bongnak
bongnak's Avatar
bongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of light
this sometimes happen with a faulty ecu ive seen three ecus on three dif cars do this SR20det.
Zzzz
bongnak is offline   Reply With Quote
Old 01-08-2008, 03:53 PM   #14
johngriff
johngriff's Avatar
If the lights are still on, on the dash board after the stall, its in the ignition system, not the ems.
[email protected]
Old 01-08-2008, 06:07 PM   #15
gippy87
figured it out. I removed the alarm installed by the previous owner and repaired the harness under the driver side fender and everything works great now.
Old 01-08-2008, 06:18 PM   #16
Sonic Motor
www.SonicMotor.com
Sonic Motor's Avatar
Trader Rating: (113)
Sonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfection
Feedback Score: 113 reviews
Send a message via AIM to Sonic Motor
good to hear that you find the problem. I was just about to tell you to check the wiring underneath the steering wheel.
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK )
Sonic Motor is offline   Reply With Quote
Old 01-08-2008, 10:34 PM   #17
deesz
deesz is making a name for him/her selfdeesz is making a name for him/her self
sounds like your tumbler switch is going out.. maybe that simple...
deesz is offline   Reply With Quote
Old 01-08-2008, 10:37 PM   #18
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Hmm... i was gonna say your main ignition relay is bad and staying closed... but looks like everything is good now. Grats.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 01-08-2008, 10:39 PM   #19
gippy87
well its been a whole day of driving and still no issues. Headligths still didnt go down after repairing the harness but now im thinking i might have burnt out the relay for headlights when the wires were all touching eachother in the harness.
