Old 12-17-2007, 01:47 PM   #1
ripnbst
ripnbst's Avatar
ripnbst is making a name for him/her selfripnbst is making a name for him/her selfripnbst is making a name for him/her self
Question Guys sliding on mostly stock KA's ? for ya
Sparknotes: Guys sliding on mostly stock DOHC KA motors what size/kind of tires are you doing it on?
Long Verison: What are you running for wheels/tires? I have intake and exhaust IE stock and a J30 LSD. I am looking to hit some events this upcoming season and I recently bought some wheels. They 9.5" wide rears and 7" wide fronts. I am thinking my stock DOHC will have a real tough time keeping 9.5" of some decent tires spinning but I got them for the street. I also have a different pair 7" wide for the rear but I dont know if it will even handle that with good rubber. So again my question is what wheels and tires are you guys sliding on? I see lots of guys just running stock SE wheels. Are you running Federals, Falken, something similar like lots of guys on here? I plan on buying a different set of tires for the other 7" wide pair if possible as a drift set. Or if that is not practical on a stock KA then run dif tires on the stock SE alloys.
In the market for a Clean Coupe
ripnbst is offline   Reply With Quote
Old 12-17-2007, 01:52 PM   #2
!Zar!
!Zar!'s Avatar
Kick the clutch and rev the shit out of it.
It's doable.
A good clutch helps also.
Old 12-17-2007, 02:09 PM   #3
txrxs
txrxs's Avatar
txrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfection
I would say dumpster tires. It really depends on the level you are at? Are you just starting out or what? I'm assuming from your question you're just starting out. Rock the stock wheels with whatever tires you can pickup in the rear. It will make your car seem a lot more powerful then it is. You will not be moving as fast as the other drivers but it will help you get used to the car in a drift + it will be easy on the wallet. Run good rubber in the front for sure though.
DRIFTINDY
txrxs is offline   Reply With Quote
Old 12-17-2007, 02:11 PM   #4
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
alot of air on the tires
i think some people would agree with me on this
basic knowledge
Drift Indy
Edgar is offline   Reply With Quote
Old 12-17-2007, 02:12 PM   #5
tknbkthrsdy4anfg
tknbkthrsdy4anfg's Avatar
tknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfection
Send a message via AIM to tknbkthrsdy4anfg
On a 17 x 8
I've drifted 235 50 17 Yokohama S-drives @ 45, too much grip.
235 40 17 Kumho Ecsta ASX's @ 45, weren't bad... still a little too much grip.
I think a 225 would be perfect, however I like my car to be pretty neutral.
I think BRIAN would be the best guy to ask, he kills on a stock KA.
Originally Posted by Brian
well I suppose you can imagine it like a parking space that you think "gosh, I’ll never fit in there" But then you fold in the side view mirrors and what do you know, your in.
$pending dead pre$ident$ J@CK@TT@CK!
tknbkthrsdy4anfg is offline   Reply With Quote
Old 12-17-2007, 02:14 PM   #6
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
I have a shitty low power Single cam
I did this on 215/45 used tires on a 9" wheel
215's on a 9 are money imo, run pretty high pressure in them, like 40 or a bit more, depends on what tire you have. Good to go, as long as you aren't a pussy and afraid to beat on your car.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 12-17-2007, 02:15 PM   #7
A Spec Products
A Spec Products's Avatar
15's are easier
When I was 15's I just ran whatever tires I could in the back
For the fronts I'd try to run a semi decent tire, or at least a poo poo tire with lot of tread
For a while I ran 17x9 fronts with 15x7 on the back at the track (cheap guy style)
But when I went to 17x9+15 all around with 215/45/17 it was fine
In fact I think the car felt better at that point
No need real high pressure, but it helps
Just gotta drive faster on the track
Plus 17's look better in the pics
Not like wimpy 15's
A SPEC PRODUCTS CORP
Old 12-17-2007, 02:17 PM   #8
240trainee
240trainee's Avatar
I liked sliding on 17's much better than 15's, felt much more solid.
wasn't really any harder to slide I thought, was much better feeling though.
Especially better than a 17/15 staggar, that shit sucks.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
Old 12-17-2007, 02:22 PM   #9
drifting.8
drifting.8's Avatar
Location: What's heavier a pound of iron or a pound of feathers??
drifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud of
Send a message via AIM to drifting.8
i run hachi wheel's take some modifcation to get um on and i run like 60 psi haha runumhard!!!
RB 25DET NiZTECH BUILT
drifting.8 is offline   Reply With Quote
Old 12-17-2007, 02:24 PM   #10
ZX88
ZX88's Avatar
15 would be the easiest to slide with a ka but with 17 get some light weight wheels its a bitch to try to spin 29lbs shitty sportmaxs. I would go 17x9 or 8 and 215/40 for tire size.
Old 12-17-2007, 02:38 PM   #11
mrs.drift33
Banned from the Marketplace
mrs.drift33's Avatar
mrs.drift33 has a reputation beyond reputemrs.drift33 has a reputation beyond reputemrs.drift33 has a reputation beyond reputemrs.drift33 has a reputation beyond reputemrs.drift33 has a reputation beyond reputemrs.drift33 has a reputation beyond reputemrs.drift33 has a reputation beyond reputemrs.drift33 has a reputation beyond reputemrs.drift33 has a reputation beyond reputemrs.drift33 has a reputation beyond reputemrs.drift33 has a reputation beyond repute
185/60/14....spin ALL DAY!
haha
On a serious note, Ived noticed most underpowered ka guys rock 15" steelies in the back.
mrs.drift33 is offline   Reply With Quote
Old 12-17-2007, 02:44 PM   #12
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
i ran 15s all around on my KA.. my buddy runs 17s and sometimes he doesnt get the over steering he is looking for.. with 15 over steer is ohh so easy!
Brian i think rocks 18s? and he kills them in is pretty stock KA, i think his suspension helps out also.
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 12-17-2007, 03:43 PM   #13
ripnbst
ripnbst's Avatar
What is Brian's s/n on here?
Old 12-17-2007, 02:47 PM   #14
916S14
916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known
Stock se wheels. Drift those.
916S14 is offline   Reply With Quote
Old 12-17-2007, 03:43 PM   #15
ripnbst
ripnbst's Avatar
Thanks for all the input, the wheels I got are 17's. They are Falken Hanabi's so they are pretty light for 17's. I got 6 of em, four in 17 X 7 and two in 17 X 9.5 for rear. I think I will prolly run the 17 X 7's all around with a mad stretched tire in the rear and adjust pressure as I think it feels the best. I am just starting out so +1 for that guess. I already have 4 hard crappy tires that I got when I bought the car so I will use those first, then try the Hanabi with better tires. Worst case scenario I like the 15's more and I can sell the extra pair of Hanabi for more tires
Old 12-17-2007, 03:47 PM   #16
deadpirate
deadpirate's Avatar
deadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfection
Send a message via AIM to deadpirate Send a message via Yahoo to deadpirate
i believe its brian^^
On Track Motorsport Supply-saftey stuff call TOM @ (805)484-3435
deadpirate is offline   Reply With Quote
Old 12-17-2007, 04:23 PM   #17
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Oh hi, did somebody say my name?
I do this.
I have a stock KA... cone filter and exhaust.
front - 17x9 215/40-17 Federal SS595
rear - 17x9 215/45-17 Federal SS595
easy to spin these. they are perfect for me.
I use them brand new. That is when I love them the best.
Different tires work different though.
example - i USED to run 225/45-17 Falken ST115. I LOVED them. perfect they were.
Then one day I tried the 225/45-17 Federals..... SUCKED. they (in my opinion) are more grippy and probably even run a little wider.
So this is why I moved down to the 215/45 federal. They feel the same as the slightly larger Falkens.
ANy more questions? Ask me.
http://bhworld.wordpress.com/
Old 12-17-2007, 04:30 PM   #18
projectdrifter
projectdrifter's Avatar
projectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of light
Send a message via AIM to projectdrifter Send a message via Yahoo to projectdrifter
stock ka. 17 inch do do rims. kyb and springs
cary some speed kick the clutch cary it thru. go hard or go home. ohh yea open diff. 4 the win. lol get it welded
Mouth of the South
There are a few mailboxes that have been looking at me the wrong way, lately. Nothing goes unchecked.
projectdrifter is offline   Reply With Quote
Old 12-17-2007, 05:14 PM   #19
PhilVia
PhilVia's Avatar
PhilVia is a glorious beacon of lightPhilVia is a glorious beacon of lightPhilVia is a glorious beacon of lightPhilVia is a glorious beacon of lightPhilVia is a glorious beacon of lightPhilVia is a glorious beacon of lightPhilVia is a glorious beacon of lightPhilVia is a glorious beacon of lightPhilVia is a glorious beacon of lightPhilVia is a glorious beacon of lightPhilVia is a glorious beacon of light
i have a ka and 15" seems the best and cheapest for me...
if you need i have a set for sale slide in style lol
AINOKEA......
PhilVia is offline   Reply With Quote
Old 12-17-2007, 05:46 PM   #20
BlckBeautyVTEC
BlckBeautyVTEC's Avatar
BlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really nice
Send a message via AIM to BlckBeautyVTEC
just like brian i run a 215 40/45 17 Federals on either a 9 or 9.5 inch rim you just have to get mean with it. BTW get rid of that 7inch wide rim for your fronts and get some 9 atleast
poop mama...
BlckBeautyVTEC is offline   Reply With Quote
Old 01-10-2008, 03:48 PM   #21
blackcoupe
blackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the rough
what would you guys recommend for a 17x9F and 17x10R set up? with federals or falkens.
Last edited by blackcoupe; 01-10-2008 at 03:49 PM.. Reason: I know this is a one year old thread.
blackcoupe is offline   Reply With Quote
Old 01-10-2008, 04:17 PM   #22
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
I'm a GRIP driver but on the cool down laps I like to hold the car in a slide on corner exits as long as I can...
Stock KA spinning 245-40-17 Bridgestone RE01-Rs...
Nikeboy355 is offline   Reply With Quote
Old 01-10-2008, 04:21 PM   #23
TheSquidd
TheSquidd's Avatar
Hm. Shit.
18x9.5
I'll try 215/40?
Lots of air?
Heavy foot and a new clutch?
Welded?
TheSquidd is offline   Reply With Quote
Old 01-10-2008, 04:31 PM   #24
blackcoupe
damn im thinkin either 215/40 all around or 225/40 all around. definitely lots of air and a whole lotta clutch destruction.
Old 01-10-2008, 04:31 PM   #25
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Stock KA. Only AEM intake and 4" exhaust.
F:17x9 RT-615 235/40
R:17x9 ST-115 245/40
VLSD Stock stock clutch.
I drift just fine. Just need a bit more speed going into the drift that's it.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 01-10-2008, 04:39 PM   #26
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
Here's a new idea: The REAL Drift Button
Re-route your washer fluid hoses to point at the contact patches of your rear tires. Voila! Now pull on that wiper lever, AUTOMATIC LOSS OF REAR TIRE CONTROL!!!!!!!!!! AND it saves on tire life.
HAHAHHAHAHAHAH. Good shit.
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 01-11-2008, 08:17 AM   #27
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
lol i bought lines and an extra reservoir so i could fill it with bleach for lots of smoke.
I never got to it tho since i how have a sr and i dont need the water to help me slide.
projekt_s13 is offline   Reply With Quote
Old 01-10-2008, 04:40 PM   #28
MrChow
MrChow's Avatar
^^ My friends wanted to do that to my car when I first going drifting. Lol
Last edited by MrChow; 01-10-2008 at 06:06 PM.. Reason: edit: I know english I swear!
Old 01-11-2008, 08:09 AM   #29
240trainee
240trainee's Avatar
Went out and slid my hatch with steelies on it last night.
sucked
I dunno why you guys do it still.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
