Old 01-11-2008, 11:03 AM   #1
harangatang
harangatang's Avatar
harangatang can only hope to improve
Weird Sr boost Problems
So.. I searched, but I didnt really see anything close to this so
Ok, on stock boost, ~7-8 psi, its fine all day. Hits 8psi, whatever
If I turn it up to ~10-11, it will hit full boost once then it won't go over like 1-2 psi. If I turn the car off, leave the boost controller alone, turn it back on, it will hit 10-11 psi once, then not go over 1-2psi again.. Even at 3/4 throttle.
If I turn it back down to 7-8psi, its fine all day..
So, I really have no idea what the cause of this could be.. bad boost controller (I have a HKS manual), bad wastegate, electronic issues...
Help me out guys!
harangatang is offline   Reply With Quote
Old 01-11-2008, 11:31 AM   #2
IStop4NoMan
IStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant future
I would take a guess and say your wastegate is getting stuck open after you hit the higher boost? maybe a new actuator is in store for you.
IStop4NoMan is offline   Reply With Quote
