Old 01-11-2008, 06:44 PM   #1
heyitzalan
heyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant future
HKB Boss Hub Kit question
Hey guys, i wonder if this will disable my airbag light?
there is a airbag harness, i don't know where the other small pin connector go to, since rhdjapan parts are from japan, will it work on usdm 240sx? :hammer:
https://www.rhdjapan.com/jdm/Boss-Ki...-Air-Bag-26244
heyitzalan is offline   Reply With Quote
Old 01-11-2008, 06:50 PM   #2
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
I believe so. Don't quote me on that.
frsport.com as one you may want to look at. If not talk to aspec and get WB hub they'll have it.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 01-11-2008, 08:11 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Do a search, I know for a fact OptionZero did a write up and he used the HKB hub (I followed his guide 2 years ago). I just cant remember exactly which wires are which but the HKB hub should have a resistor in it that tricks the ECU into thinking the air bags still there. This will cause your check engine light not to turn on and your passenger side air bag to still work. The other wire should be for your horn to work. Do a search or PM if and he should be atleast able to link that write up for you. It was a pretty awesome guide, got all the pictures you need...
CLICK HERE!!!
