Old 01-12-2008, 10:08 AM   #1
jakethesnake
jakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymore
SR lifter noise
i finished my SR20DET swap and i started my car and my valves are very very loud, is that normal?? i drove it twice around the block and i thought that maybe once oil got into the valves it would go away but it didnt yet. Whats going on with that? Is that a normal thing for SR's? Please help..
jakethesnake is offline   Reply With Quote
Old 01-12-2008, 10:12 AM   #2
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
you sure its a valvetrain noise?....is it a loud ticking noise coming from the intake side?
ecuastyle84 is offline   Reply With Quote
Old 01-12-2008, 10:12 AM   #3
lob@ller
lob@ller's Avatar
lob@ller will become famous soon enoughlob@ller will become famous soon enoughlob@ller will become famous soon enoughlob@ller will become famous soon enoughlob@ller will become famous soon enough
Did you bleed the lifters?
lob@ller is offline   Reply With Quote
Old 01-12-2008, 10:13 AM   #4
Xracer
Xracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to beholdXracer is a splendid one to behold
Send a message via AIM to Xracer
did you take the head apart? there are shims on the rocker arms that adjust valve clearance, if they are out of spec they will cause noise.
R34 NEO POWER
Xracer is offline   Reply With Quote
Old 01-12-2008, 10:43 AM   #5
jakethesnake
no i did not bleed the lifters?? how do you do that?? and do i have to do that when i fist swap my car??
Old 01-12-2008, 11:05 AM   #6
ecuastyle84
put them in oil and find some thing thin enough to bleed the lifters...the lifters should compress when you bleed them...there should be a hole on top the lifter and i think there was a smaller hole in that hole and then the ball bearing. So look for the thinest thing you can find to bleed them
Old 01-12-2008, 11:08 AM   #7
tknbkthrsdy4anfg
tknbkthrsdy4anfg's Avatar
tknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfection
Send a message via AIM to tknbkthrsdy4anfg
I hope this helps, go about halfway down CLICK HERE
Originally Posted by Brian
well I suppose you can imagine it like a parking space that you think "gosh, I’ll never fit in there" But then you fold in the side view mirrors and what do you know, your in.
$pending dead pre$ident$ J@CK@TT@CK!
tknbkthrsdy4anfg is offline   Reply With Quote
Old 01-12-2008, 11:50 AM   #8
jakethesnake
how do u adjust the clearence??
Old 01-12-2008, 11:56 AM   #9
tknbkthrsdy4anfg
They do it hydraulically. Oil pressure pushes up on the lifter and keeps the rocker in constant contact with the cam.
Old 01-12-2008, 12:22 PM   #10
lob@ller
lob@ller's Avatar
Sometimes injectors can make a ticking noise that sounds like the valvetrain. Although it's usually not very loud. Anyway bleeding the lifters is not very difficult. Just a little time consuming. The write-up in this thread is good.
Old 01-12-2008, 12:26 PM   #11
ecuastyle84
thats exactly what i was thinking at first about the injectors but yea like you said anyways bleeding the lifters is not hard....the link that tknbkthrsdy4anfg gave is good help
Old 01-12-2008, 12:46 PM   #12
tknbkthrsdy4anfg
Thanks guys, I had to do it twice because I turned the motor over.
oops. Anyways pump those lil buggers!
Old 01-12-2008, 08:46 PM   #13
jakethesnake
thanks everyone for the help
Old 01-14-2008, 06:40 AM   #14
jakethesnake
does anyone know where u can order or just go and pick up some Lifters?? and what kind of car should i tell them its for?? 91-94 sentra SE-r?
