Old 04-29-2008, 02:16 PM   #1
chituntang
chituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nice
s14 Is my S14 a 95 or a 96??
I know a lot of you are going to say things like vin plate and stuff like that, but the thing is the car's title is a 95, but when I was doing some wiring tucking, I see that the F4 plug's pin out is the same as a 96. I am asking because I want to fix my driver side window which has not work since about an year ago. I want to think it out what year it is before I try to do more wiring stuff.
Thanks in advance
Jesse
chituntang is offline   Reply With Quote
Old 04-29-2008, 02:20 PM   #2
Phlip
Yes, I look like that
Phlip's Avatar
What is on the plate on the door jamb? Usually it has the "built on" date there, which should place you another step in the proper direction
Weirdo
And I write too!
Old 04-29-2008, 02:21 PM   #3
Phil703
Phil703's Avatar
Phil703 is not welcome here anymorePhil703 is not welcome here anymorePhil703 is not welcome here anymorePhil703 is not welcome here anymorePhil703 is not welcome here anymorePhil703 is not welcome here anymorePhil703 is not welcome here anymorePhil703 is not welcome here anymorePhil703 is not welcome here anymorePhil703 is not welcome here anymorePhil703 is not welcome here anymore
Did you check the door jam? And I didn't know that you had to find out the year of the car before you start wiring?
^ Damnit philip.
Phil703 is offline   Reply With Quote
Old 04-29-2008, 02:21 PM   #4
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
do what philp said
-los
los_inc is offline   Reply With Quote
Old 04-29-2008, 02:21 PM   #5
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Damn, I was all set to come in here yelling STUPID NOOB!!!!! and crap like that.
This plug you're talking about is different from 95 to 96? If so...what's your car's history? Is it possible the original engine gave up and get replaced with one from a 96? With the amount of pulling and swapping these cars go through, it wouldn't surprise me.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 04-29-2008, 02:38 PM   #6
Farzam
Farzam's Avatar
See if your motorset/ECU is OBDI or OBDII
See if your VIN #'s match up on your chassis/dash/motorset/etc.
Farzam is offline   Reply With Quote
Old 04-29-2008, 02:44 PM   #7
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
your car is a 95, i've tried to research why some 95's have the 96 wiring harnesses, and it doesn't matter about the production date whether it's an early model or a late model some of em have one harness and some of em have the other. i was thinking possibly it could be where they were assembled but that's as far as i went. before i wired a motor into anyone's s14 i'd always check the f4 pinout functions (well you kind of have to anyways to wire the new motor in there).
anywho, you're not the first one, if you're unsure on what you're doing just bring it by the shop or call and i'll see what i can do, since you're in GA
Dave @ Lethal Injection Motorsports www.lethalmotorsports.com
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 04-29-2008, 03:37 PM   #8
projectRDM
projectRDM's Avatar
Open the hood. If there's a carbon canister against the core support right by the airbox it's a 95. End of story.
FORMERLY R240NA
Old 04-29-2008, 05:32 PM   #9
timlush
timlush's Avatar
timlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to behold
Send a message via AIM to timlush
So the 96+ doesn't have it? Where is the fuel tank vented?
timlush is offline   Reply With Quote
Old 04-29-2008, 10:28 PM   #10
projectRDM
projectRDM's Avatar
EVAP canister, behind the rear passenger tire. Pretty much like all 96+ Nissan vehicles.
FORMERLY R240NA
Old 04-29-2008, 05:45 PM   #11
SinisterSntra91
SinisterSntra91's Avatar
SinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfectionSinisterSntra91 is close to perfection
write down your vin number off the plate in the engine bay, use this link to decode it:
http://garage.projectraine.com/conte.../vinmid01.html
Your welcome.
SinisterSntra91 is offline   Reply With Quote
Old 04-29-2008, 06:55 PM   #12
silnismo
silnismo's Avatar
silnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enoughsilnismo will become famous soon enough
you can check by the grill.
95= double fined design
96= no fins, open grill
silnismo is offline   Reply With Quote
Old 04-30-2008, 09:30 PM   #13
chituntang
Well, I checked all those things that I am supposed to check and it is a 95. I just want to make sure that why a 95 has a 96 F4 plug. I was doing my A/C stuff as well as trying to organize my wiring a bit everyv since my AFC and AVCR install.
Dave, I talked to you a while ago (more like a year). You were too busy and was forced to get the SR swap somewhere else. And thanks for your help.
I have been doing all the work on my cars (S13 before and S14 now) other than the motor swap (no garage FTL). I was going though to hook up the A/C for the car since it is getting hot in ATL (not this week). Then I found out there is two different pinout for the F4 plug which is based on the year, according to the guide.
