Old 02-14-2008, 02:54 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
ka throttle body on sr
ok ive gota dohc ka tb going on an s14 sr, so i can keep cruise control.
one thing i have noticed, is that the sr throttle body inner diameter is much smaller. will the larger inner diameter create a problem, as i am running a very oem setup.
also the way the hoses hook up is different.
finally, the throttle position sensors are different, which i guess means i will need to be splicing wires?
can anyone shed some light on this?
it just seems the nico writeup about this was so vague, and made no mention of these things i have noticed.
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 02-14-2008, 11:59 PM   #2
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
the easy way is to get a s14 sr20de (na motor) throttle body and slapping it on. Its a bolt on affair besides swapping over the TPS. Good luck trying to find one tho, i've had a hard time myself.
eek is offline   Reply With Quote
Old 02-15-2008, 12:12 AM   #3
S14DB
AFC #1
S14DB's Avatar
The S14SR is a high port where as the S13SR and all the KA's are low port intake manifolds. You will find that the pulley is going to be 90* out from the cable brace. Best solution is a s14 sr20de with CC.
Old 02-15-2008, 07:37 AM   #4
devonkyle77
thank you, finally got the answer i needed
repped
Old 02-15-2008, 08:01 AM   #5
devonkyle77
by the way s14db, could a fwd sr20de tb work?
or s15?
thanks in advance!
