skyline turbo questions??
Does anyone know the specs on a stock R34 skyline turbo? i know its a t28 ball bearing and says .48 as opposed to .60 s15 turbo. and it has to be bolted to a top mount manifold. ive heard of people running between 21-25 psi with no problems whereas the s15 isnt recommended to go over 15. but does anyone know the actual max recommended boost? is anyone running them on an sr20? how much hp can u expect? interested in mounting it i also have an s15 turbo is it worth it to switch
#3 | |
Man w/ CTSV & a Car Seat
How do you get it to bolt up to a bottom mount manifold? I tried a megan, hks, and the stock manifold. None of them fit. The compressor side runs into the runners. do you need a spacer(kinda like a flange adapter)? if not how do you re clock it because if u rotate the compressor housing there is no where to bolt the actuator
![]() Join Date: Jan 2007
Try using an SR20 Wastegate actuator I'm pretty sure that is the solution once you clock it. I'm not familiar with R34 stuff but if it is the same as the 33's then that is money.
i would but im saving up for a gt35r. i just needed a turbo to tune my aem ems on for the meanwhile because my bitch ass t25 blew up on me.btw what engine management are u on
Ya no problem.. Its a shame tho because the turbo r34 only only has 6k miles on it where as my s15bb has like 65-70k. As for fabricaton what would be needed to make it work because a buddy of mine is interested in buying it? is it just a spacer so the runner doesnt hit the turbo and a different compressor out flange because i already made one out of an old greddy bov flange and a 90 degree bend pipe? any info will be helpful.
