Old 02-19-2008, 12:35 AM   #1
o_0-Alex-0_o
o_0-Alex-0_o's Avatar
o_0-Alex-0_o is an unknown quantity at this point
Have a problem. need help :/
ok so my clutch master cylinder went out so i changed it and i bled the clutch and the clutch pedal still didnt have any pressure so i bought a new slave cylinder and that didnt seem to work either so i returned the clutch master cylinder thinking it was that and i put it on again bled the line and it still doesnt work. dont know what to do
o_0-Alex-0_o is offline   Reply With Quote
Old 02-19-2008, 12:43 AM   #2
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
still got that loop in the hard line? keep bleeding. things a bitch
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 02-19-2008, 12:52 AM   #3
o_0-Alex-0_o
yea my sis bf told me the same thing happened to his 510
Old 02-19-2008, 01:21 AM   #4
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Did you bench bleed the master cylinder? If not then it will take FOREVER to get all the air out. Also if you still have the dampener thing in the system it takes a while to work all the air through that as well. I think the dampener has it's own bleeder, try bleeding there as well.
Old 02-19-2008, 01:33 AM   #5
johngriff
johngriff's Avatar
start bleeding by backing the line off the master cylinder. open/close
then the dampner, then the slave.
Or just go single steel braided line, I did mine from all dry to pressurized in 5mins today.
[email protected]
Old 02-19-2008, 01:50 AM   #6
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
remove the bleeder box.
sblack13 is offline   Reply With Quote
Old 02-19-2008, 08:49 AM   #7
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
^^ yup what he said, delete the dampener. it sucks.
1) pretty much unbolt the dampener system from the bottom of the car.
2) bend the hardline carefully toward the clutch slave
3) screw the clutch slave line to the hardline.
getting a ss clutch line is recommended too, but not required I believe.
ooooooooor you can just keep bleeding. like for a really long time. Eventually it'll work.
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 02-19-2008, 04:06 PM   #8
o_0-Alex-0_o
k thnx ill try it today
Old 02-19-2008, 05:27 PM   #9
o_0-Alex-0_o
problem solved thnx for the help
