Old 02-19-2008, 07:34 AM   #1
redline454
redline454 will become famous soon enoughredline454 will become famous soon enoughredline454 will become famous soon enoughredline454 will become famous soon enoughredline454 will become famous soon enough
s13 sr20det shakes like hell
for the past 3 months my s13 has been running fine then one day i turn it on and it has a lowww rpm 8-900 it was used to idling at around 1500. it doesnt want to accelerate at all. motor shakes like hell! im wondering if anyone had the same problems idk if its motor mounts, coils, something please help
redline454 is offline   Reply With Quote
Old 02-19-2008, 07:44 AM   #2
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
FYI, your engine is supposed to idle around ~800RPM. If it idles at 1500 you've got something wrong somewhere, like a vacuum leak.
As for the acceleration problems and shaking: Motor mounts aren't going to affect your idle speed. Check your coil packs, pull them off one at a time and see if pulling one of them doesn't affect the way the engine's running. If you find that, use a timing light to see if the coil is getting spark.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 02-19-2008, 07:53 AM   #3
Slow Poke
Slow Poke's Avatar
Slow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really nice
Have you ever checked the timing on your motor?
Slow Poke is offline   Reply With Quote
Old 02-19-2008, 08:14 AM   #4
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
yeah check your timing supposed to be 16*, look for boost leaks, your motor mounts are probably shot as well, as with most of the sr's rocking the stock mounts i've seen.
Slip Gypsies Blog
not sure if you realize this
Old 02-19-2008, 09:02 AM   #5
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
yeah check for vaccuum leak... ie intercooler piping
reccakun08 is offline   Reply With Quote
