Old 02-28-2008, 06:24 AM   #1
turbo_ls_civic
turbo_ls_civic is on the path to ruinturbo_ls_civic is on the path to ruin
Front camber kit for 240sx?
Ok i am going to lower my 95 about 1.8 inch and here is the problem. I found rear camber kit for it but i can't seem to find front camber kit except for camber plate? Sorry i been a Honda person and this is my first 240sx and have been looking around here for a bit now.Can someone tell me if i even need a front camber kit for the 240sx or where to find one..or the CAMBER PLATES are what needed
turbo_ls_civic is offline   Reply With Quote
Old 02-28-2008, 06:32 AM   #2
S14DB
AFC #1
S14DB's Avatar
Camber Plates are the best but you can notch the upper bolt holes on the spindle bracket of the shock.
How are you dropping the car? That is a lot for springs.
Old 02-28-2008, 06:33 AM   #3
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
ok well since everyone in the honda world loves using the words camber kits, here's an explanation... for a 240sx, in the front you use camber plates, and the rear you get RUCAs, or rear upper control arms... So for the front get plates...
Slip Gypsies Blog
not sure if you realize this
Old 02-28-2008, 06:40 AM   #4
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
in the front you can control:
camber - camber plates
toe - tie rods
caster - tension rod
in the rear you can control:
camber - rear upper control arm
toe - traction arm and toe link
edit: punxva you beat me to the post, lol.
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
