Old 02-26-2008, 06:02 PM   #1
180ways2slide
180ways2slide's Avatar
180ways2slide is making his/her stupidity well-known180ways2slide is making his/her stupidity well-known180ways2slide is making his/her stupidity well-known
SR tranny problem
i just swapped trannys on my sr cause the shaft messed so i took my ka tranny an use the sr bell housing as told. when i turn the key while in nuetral the motor jumps forward slighty but when the clucth is pressed in no movement(dont need clutch to start)tranny has been sittingt for a while i put some royal purple in there. it doesnt jump every time but most of the time it does is there some thing i should look for or check.
180ways2slide is offline   Reply With Quote
Old 02-26-2008, 06:08 PM   #2
91redMS13
91redMS13 is a jewel in the rough91redMS13 is a jewel in the rough91redMS13 is a jewel in the rough91redMS13 is a jewel in the rough91redMS13 is a jewel in the rough91redMS13 is a jewel in the rough91redMS13 is a jewel in the rough
So it jumps as if you had it on gear when you're starting it?
There's a possibility that the fork in the tranny is bent & that it's engaging 1st.
91redMS13 is offline   Reply With Quote
