Old 03-15-2008, 10:31 AM   #1
longhorntx09
longhorntx09 is an unknown quantity at this point
ka24de rough/moderate acceleration
Hi, I'm having problems with my ka24de. When you first accelerate it has a very rough start, it spits/sputters, then once at a higher speed it runs a bit smoother...any ideas what could be causing this problem ? Already changed spark plug wires..but that's it. Think it could be a fuel problem ? maybe I need a new fuel regulator ? help please thanks
longhorntx09 is offline   Reply With Quote
Old 03-15-2008, 10:46 AM   #2
LFOabuse
LFOabuse's Avatar
LFOabuse is making a name for him/her selfLFOabuse is making a name for him/her self
Check your timing.
LFOabuse is offline   Reply With Quote
Old 03-15-2008, 11:02 AM   #3
longhorntx09
Originally Posted by LFOabuse View Post
Check your timing.
It's not the timing =/
Old 03-15-2008, 11:15 AM   #4
CSil80
Banned from the Marketplace
CSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfection
Have you checked anything out at all?
Injectors, spark plugs, electrical connections, fuses, vacuum lines, etc?
ECU throwing any codes?
CSil80 is offline   Reply With Quote
Old 03-15-2008, 11:25 AM   #5
SLeepingPanda
SLeepingPanda's Avatar
SLeepingPanda is an unknown quantity at this point
Send a message via AIM to SLeepingPanda
do a compression test... it might be bad rings, bad valves, or a headgasket. Did you notice any smoke out the tail pipe. White smoke to be specific?
Simply Sophisticated...
SLeepingPanda is offline   Reply With Quote
Old 03-15-2008, 01:13 PM   #6
longhorntx09
spark plugs are good, and fixed the vacuum leak. haven't really gotten any further than that. haven't checked the codes yet
Old 03-15-2008, 01:15 PM   #7
longhorntx09
nope, no smoke at all.
