Old 03-06-2008, 03:39 AM   #1
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
Coolant reservoir
whats the purpose of the coolant reservoir? mine is cracked and below the minimum, is that a problem?
s13boy89 is offline   Reply With Quote
Old 03-06-2008, 03:43 AM   #2
S13Leprechaun
S13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant future
its an "over flow"... almost everyones is cracked! ITS OK.... just tape it or junkyard search it... just keep it like 1/2 or less full.
thurs. knights.
S13Leprechaun is offline   Reply With Quote
Old 03-06-2008, 03:44 AM   #3
s13boy89
s13boy89's Avatar
also when bleeding the system, do you put the heater on high AND turn the heater on? with the rad cap off?
Old 03-06-2008, 03:48 AM   #4
S13Leprechaun
just try a bunch of different cool shit and see what happens and what doesnt happen!
thurs. knights.
Old 03-06-2008, 04:43 AM   #5
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
open the beather valve. on the water neck.
filler up to the top.
run car and see if the coolent goes down.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 03-06-2008, 05:33 AM   #6
s13boy89
s13boy89's Avatar
where is the water neck at?
Old 03-06-2008, 06:49 AM   #7
Phlip
Yes, I look like that
Phlip's Avatar
At the end of your upper radiator hose with your radiator.
Please don't end sentences with "at," please?
Weirdo
And I write too!
Old 03-06-2008, 06:59 AM   #8
sofo259
sofo259's Avatar
sofo259 is an unknown quantity at this point
do you really own a 240 ?
if its a KA theres a little sticker that says "do not open when hot"
thats the little screw you need to open, and green stuff comes out
sofo259 is offline   Reply With Quote
