![]() Join Date: Sep 2003
sr20det ecu help
i have a s15 sr20de swap
trying to covert over to cam angle sensor i need some of your help i know you guys might not can help me but try your best please ok the s13 sr20det ecu 61 62 63 runs with 4 wires for the ignitor chip with 4 pins to the ecu. for the ignitor chip. which is 1,2,8,9 the cam angle sensor runs with the 38,47,46,48,39 the s14 sr20det e5 e6 wc im not too familiar with this harness can some body explain the cam angle set up and the DIS setup or even a wiring diagram for me the s15 i know for a fact that the ignitor are on each coilpack. my question is-- are the later year s14 kouki harness simluar to the s15 harness does the later year kouki swap comes with the ignitor chip as well |
AFC #1
![]() Join Date: Oct 2003
S13/14 needs an ignitor. S13/14 use the same coils. S15 is totally different. You can get a S14 Harness, ECU, coils and ignitor to run the S15 motor. Just have to compensate for the injectors if they are not 370's.
Zenki and Kouki harness pinouts are different. Make sure you have matching harness and ecu if you go this route.
