![]() Join Date: Feb 2008
![]() I just replaced my old rusty gas tank and finally got my SR to start. She idles fine around 800ish but smokes like hell and smells like gas. I'm running stock injectors and FPR, 255 walbro, and T25.
Pulled code 11, which is camshaft pos sensor. So I'm guessing I got the base timing wrong. I just lined the crank up with the second notch on the left and with the dots on the cams. I dont think my timing chain has the different colored guide links. What do you guys think? Oh, my starter is starting to grind and I get this weird grinding noise when I press the clutch. Should I have gotten a new pilot and throwout bearing when I did the swap? Last edited by flip3d; 03-20-2008 at 08:39 AM.. Reason: cam pos sensor not crank. d'oh! |
![]() Join Date: Apr 2007
check the cts, check for boost/vac leaks, check your maf, check to make sure your getting proper amount of spark from your coils
"I am Norwegian, and are not familiar with your urban words :P" |
Hah. Nevermind. I found the problem. One of my injector O-rings finally gave way.
So new o-rings, new plugs, and im back on the road ![]() Code 11 only beacause I was cranking without the CAS plugged in. |
