Old 03-17-2008, 08:41 PM   #1
chibich
chibich is an unknown quantity at this point
redtop O2 sensor wiring question for universal O2
I have a couple things to finish up on my swap and might finally have a chance to be back in town this weekend and work on it. I was wondering if I could possible just get a universal O2 sensor and wire that into the jdm harness for my redtop, cause the O2 sensor that came with the motor has a large dent in it and don't want to have to weld in a bung if it is broken and I could just replace it with a universal one. Anyone done this or do I have to go with another jdm O2 sensor?
chibich is offline   Reply With Quote
Old 03-17-2008, 08:46 PM   #2
Sileighty_85
Sileighty_85's Avatar
Here
http://www.thenismoshop.com/ikorb.ph...roduct_id=1607
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-17-2008, 09:11 PM   #3
chibich
so you can't use a universal one from advanced or napa?
Old 03-17-2008, 11:13 PM   #4
Sileighty_85
I believe one from a 1987 280ZX will work
後輪駆動車1番
1986 SR86 - 200ish
Old 03-18-2008, 06:57 AM   #5
g6civcx
g6civcx's Avatar
Search my posts for o2 sensor. Everybody else who is clueless shouldn't respond.
Old 03-18-2008, 07:54 AM   #6
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
I went through a lot of problems with this as well, and have a bunch of posts on the topic.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 03-20-2008, 11:30 PM   #7
breakingsociety
breakingsociety is on the path to ruinbreakingsociety is on the path to ruinbreakingsociety is on the path to ruin
Send a message via AIM to breakingsociety
easy solution - http://cgi.ebay.com/ebaymotors/New-N...spagenameZWD1V
I JUST bought that. it works well. spliced it into my harness. good luck!
breakingsociety is offline   Reply With Quote
