Old 03-26-2008, 11:11 PM   #1
Magical Trevor
Magical Trevor's Avatar
Magical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the rough
Send a message via AIM to Magical Trevor
Mystery Sensor?
I've tried searching all over the place, I just got this SR20det from a friend of mine freshly rebuilt. I installed it and went to replace the turbo and manifold and found this sensor underneath the manifold was busted
Here are some pictures.
I can't figure out witch sensor it is and my buddy doesn't know either. Any help would be awesome!
Magical Trevor is offline   Reply With Quote
Old 03-26-2008, 11:17 PM   #2
MegasquirtCA
MegasquirtCA's Avatar
MegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfection
Knock Sensor.
MegasquirtCA is offline   Reply With Quote
Old 03-26-2008, 11:24 PM   #3
Magical Trevor
Well crap, where can I get a new one, because to me it looks pretty effed up.
Old 03-26-2008, 11:25 PM   #4
MegasquirtCA
Im not sure possibly one from a KA24DE?
Old 03-26-2008, 11:29 PM   #5
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Theres nothing special here just seems that someone placed a tranny sensor or some other type sensor to plug a water line port for whatever reason.
Old 03-26-2008, 11:29 PM   #6
MegasquirtCA
The weird thing is why is it their, usually Nissan puts it on the intake side.
EDIT: UNISA JECS answered it.
Old 03-26-2008, 11:33 PM   #7
kamikazekid
kamikazekid's Avatar
kamikazekid is making a name for him/her selfkamikazekid is making a name for him/her self
I know the s13 sr knock sensor is on the intake side Is it an s14 sr? plus it doesnt look like a knock sensor. there is a similar sensor like that on the tranny. very different???
Drifting is not a crime
kamikazekid is offline   Reply With Quote
Old 03-26-2008, 11:35 PM   #8
kamikazekid
BINGO!!!
Old 03-26-2008, 11:35 PM   #9
Magical Trevor
No, this is an S13 red top.
That's why this was so confusing because I couldn't figure out what type of sensor is plugged in there with the clip busted off.
Old 03-26-2008, 11:37 PM   #10
Magical Trevor
So what..? Is this the port for the banjo bolt for the coolant line for the turbo?
Old 03-26-2008, 11:39 PM   #11
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
definitely not a knock sensor
Old 03-26-2008, 11:39 PM   #12
kamikazekid
no its just a port to drain coolant from the block, its ok dude dont worry about it.
Old 03-26-2008, 11:40 PM   #13
MegasquirtCA
I thought it was a knock sensor because the CA has a knock sensor similar to that, only difference is the top portion is a see through green.
Old 03-26-2008, 11:41 PM   #14
Magical Trevor
So they just plugged a drain hole?
Old 03-26-2008, 11:44 PM   #15
kamikazekid
yeah. probly lost the original plug. if you want the KA plug might fit, its in almost the exact location.
Old 03-26-2008, 11:46 PM   #16
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Your wrong.
No, I answered the question in my first reply. Let me be a little more clear, its the water port on the block that feeds the turbo which is blocked.
Old 03-26-2008, 11:48 PM   #17
Magical Trevor
Your wrong.
Ok that's what I thought it was in the first place.
Old 03-26-2008, 11:51 PM   #18
kamikazekid
Your wrong.
fuck! your right. i wasnt paying attention to the picture. my bad guys. you can leave it plugged though. there are alot of people that dont run the water lines.
Old 03-26-2008, 11:52 PM   #19
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
But dont do what most people do, run your water lines.
Old 03-26-2008, 11:55 PM   #20
kamikazekid
very true. I run the water lines on my sr, im pretty sure there there for a reason. god, now that i look at this whole thread its actually pretty funny.
Old 03-27-2008, 12:05 AM   #21
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
I think there should be a thread titled "how much can a 240 owner get away with":
1) You dont need to run water lines on a stock Nissan T25.
2) You dont need the lower harness for your 5 speed swap.
3) You dont need a manual ecu for 5 speed swap.
4) You dont need a manual TPS for your 5 speed swap.
5) You dont need a step on your stock flyhweel.
6) You dont need a PCV system
7) Dont ever put breather filters on your Valve cover or on the IACV pipe that draws in metered filterred air from the intake.
8) Dont run altima maxima 22mm rotors with yoru 26mm or 30mm Z32 calipers just because you can get them in 4 lug and 11" diameter...lol
9) You dont need a stock knock sesnor...lol
I just laugh anytime a read shit like above, granted you can get away with all that shit but your car probably suck to...lol
Old 03-27-2008, 12:10 AM   #22
kamikazekid
lol. thats a good point about the breather filter, I wouldnt of cought the fact that that can really fuck shit up, it makes perfect sense.
I learn somthing new every day.
Old 03-27-2008, 12:17 AM   #23
Magical Trevor
Now I just need to find the fucking banjo bolts lol..
Old 03-27-2008, 05:38 AM   #24
cotbu
cotbu's Avatar
Save yourself a headache an get braided lines. I still have a banjo for oil in, but it disconnects leaving the banjo fitting and bolt attached to the block
Old 03-27-2008, 06:27 AM   #25
g6civcx
g6civcx's Avatar
This is correct. Observe the picture below.
The blue fitting is an -6 AN cap on top of a threaded fitting. This is the proper way to plug up the coolant outlet for the turbo.
This is the part number for the cap:
I don't remember the size on the threaded fitting, but it's in one of my previous posts as well as others'.
I was not running water lines on my T25 because I was removing the turbo a lot to do maintenance and test fittings. So I didn't want to slow myself down with water lines.
But others may choose not to run water lines, you should run water lines if the turbo has provisions for them. It helps longevity.
Old 03-27-2008, 06:29 AM   #26
g6civcx
g6civcx's Avatar
Can you elaborate on this one?
Old 03-27-2008, 06:48 AM   #27
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
good call, frsport now carries earls lines, and circuit sports makes a nicely priced set.
clark is offline   Reply With Quote
Old 03-27-2008, 07:18 AM   #28
S14DB
AFC #1
S14DB's Avatar
I cringe when I see these....
