Old 04-09-2008, 11:36 PM   #1
fairladysx_s13
fairladysx_s13's Avatar
fairladysx_s13 is an unknown quantity at this point
Send a message via AIM to fairladysx_s13
SR sr only gets spark on 1st cylinder
I used to have a tuned ecu that came with the engine i swapped in 2 months ago and it ran fairly well but way too rich. All cylinders were firing. i got another ecu becuase i didnt need a tuned one already since i have a stock set up basically, just bolt ons. i plug the new one in and it doesnt start. I start with spark and fuel. i have fuel but i only get spark from the 1st cylinder. i switch coils and no matter what coil is plugged into the harness for cylinder 1 it will always spark. on cylinder 2 3 and 4 i dont get any spark at all. Anyone have any ideas? I think i got another worthless ecu.
New_Era Jay
fairladysx_s13 is offline   Reply With Quote
Old 04-09-2008, 11:37 PM   #2
180sx_Drifter
180sx_Drifter's Avatar
180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection
maybe you got the wrong ecu? try another ecu and see if anything changes.
180sx_Drifter is offline   Reply With Quote
Old 04-09-2008, 11:49 PM   #3
fairladysx_s13
i would try that but i dont kno anyone with an sr swap around by me and i dont want to order one. whats the difference between ecu's? i used to have a number 62 ecu. idk what thiis one is because the number was scratched off. but i kno there are different number ecu's.
New_Era Jay
Old 04-09-2008, 11:55 PM   #4
180sx_Drifter
correct me if im wrong but i believe 62 is for redtop and 5 is for blacktop? dunno if it matters but im pretty sure if you search more you will find the right answer.
Old 04-09-2008, 11:55 PM   #5
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
I'd bet my money on the ECU, for sure.
duffman1278 is offline   Reply With Quote
Old 04-10-2008, 12:06 AM   #6
fairladysx_s13
yea i have a redtop. E5 i believe is blacktop. well i guess im ganna try another ecu and see what happens.
New_Era Jay
Old 04-10-2008, 12:33 AM   #7
driftin_180sx
driftin_180sx is an unknown quantity at this point
what number is on the new ecu. Sounds like you have a Kouki ecu. If you are trying to run a kouki ecu you will only get spark on number one because the wiring pinout are different.
driftin_180sx is offline   Reply With Quote
Old 04-10-2008, 10:48 PM   #8
fairladysx_s13
like a #63 ecu instead of a #62? How can i tell the difference? half the sticker is scratched of so idk what ecu it is. the 2 codes still on the sticker is A18-F80 G20 then theres the 2371060F10. All i kno is i have a stock redtop sr20 and i need the ecu to go with it.
New_Era Jay
Old 04-10-2008, 11:52 PM   #9
duffman1278
For redtops it doesn't matter, 62 or 63 is fine.
Old 04-11-2008, 04:52 PM   #10
fishhouse
fishhouse will become famous soon enoughfishhouse will become famous soon enoughfishhouse will become famous soon enoughfishhouse will become famous soon enoughfishhouse will become famous soon enough
e5 and 62/63 should work, j4 will cause it to fire on one cylinder.
fishhouse is offline   Reply With Quote
Old 04-12-2008, 02:18 AM   #11
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
maybe the tuned ECU was a J4 (kouki s13) ecu and the previous owner had the harness repined for it. And now you're trying to use the 63 (redtop) ecu and it's not working. check the harness and repin if necessary.
driftingisgay.com
nrg is offline   Reply With Quote
Old 04-12-2008, 03:24 AM   #12
broken_s13
broken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enough
I Had the same problem a while back when i did my first sr swap. turned out i had a bluebird ecu.
broken_s13 is offline   Reply With Quote
Old 04-12-2008, 07:05 AM   #13
DDSR240
DDSR240's Avatar
DDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond repute
ITS YOUR IGNITER CHIP.....trust me if your ignighter chip is not protected from heat its more prone to fail get a new one, relocate it to a cooler spot or put some heat reflective tape on it and this one will last 4 times longer.
DDSR240 is offline   Reply With Quote
Old 04-12-2008, 08:00 AM   #14
Landers
Landers has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond repute
^^^^ Couldnt agree more...Its your ignitor chip brotha! Replace it or check wires in their connections and your car should run.
d-faction.com
Landers is offline   Reply With Quote
Old 04-12-2008, 05:36 PM   #15
sr20det drift
sr20det drift is on the path to ruinsr20det drift is on the path to ruin
i agree on the ignitor chip
sr20det drift is offline   Reply With Quote
Old 04-15-2008, 02:51 PM   #16
fairladysx_s13
i kno exactly whats going on now. The tuned ecu was a number 62. This is the ecu im suppossed to use because its a 91-94 redtop m/t. The second one i received has to be a j4. I opened it up and compared it to a fried #62 ecu i have and its completely different. Ived read using the j4 will cause to fire on the first cylinder. Im waiting for the new 62 i ordered so we'll see what happens. Im 100% positive its not the ignitor. Thanks for the ideaas though.
New_Era Jay
Old 04-15-2008, 03:44 PM   #17
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
you coulda just repinned your harness. Sorry I was too late. If your still interested, pm me, it takes like 5 mins.
"I am Norwegian, and are not familiar with your urban words :P"
jskateborders is offline   Reply With Quote
Old 04-15-2008, 03:45 PM   #18
jskateborders
if not, wanna sell the j4?
Old 04-17-2008, 10:23 PM   #19
fairladysx_s13
ill sell it. It was the wrong ecu. Cars running great. The sticker is damaged and u cant see it saying j4 but u can see the bottom of the 4 because all the other ecu's numbers arnt just a line down it.
New_Era Jay
Old 04-17-2008, 10:52 PM   #20
errolorion
errolorion has made poor choiceserrolorion has made poor choiceserrolorion has made poor choiceserrolorion has made poor choiceserrolorion has made poor choiceserrolorion has made poor choiceserrolorion has made poor choices
open up that ecu and check all the internals look for fryed circuits
check your injectors
errolorion is offline   Reply With Quote
Old 04-18-2008, 09:54 AM   #21
fairladysx_s13
The problems been solved. It was the wrong ecu.
New_Era Jay
