Old 04-18-2008, 10:33 AM   #1
SlidewayzDotNet
SlidewayzDotNet is on the path to ruinSlidewayzDotNet is on the path to ruin
13mm or 14mm Knurl whats the diff?
So im on Optionimports trying to get studs for my spacers and i do not know the difference between 14mm knurl or 13 knurl anyone hep me heres the links
14mm
http://www.optionimports.com/ni12exstsh45.html
13mm knurl
http://www.optionimports.com/ni12exstsh451.html
Im replacing the stock 300ZX rear 5 lugs hubs.
SlidewayzDotNet is offline   Reply With Quote
Old 04-18-2008, 10:40 AM   #2
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
the knurl is the portion circled.
Pretty sure all s13 f/r and s14/z32 REARS use the 13mm knurl. s14/z32 use the larger size on the fronts.
Hope that helps.
quote from PDM's Site
Longer wheel studs are necessary when adding wheel spacers thicker than 1/4 inch. These 12mm x 1.25 wheel studs are a direct replacement Nissan Pitch wheel stud that will allow you to retain your stock wheel nuts and locknuts. These 60mm wheel studs are available in packages of 5 or individually. S14 and Z32 front hubs require the larger knurl size wheel studs.
Note – S13 and S14 base model cars require 16 wheel studs in total. S14 SE and Z32 require 20 wheel studs in total.
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 04-18-2008, 10:45 AM   #3
SlidewayzDotNet
so 13mm i should get for my Z32 rears?
Old 04-18-2008, 10:46 AM   #4
rican_nick
rican_nick's Avatar
from what i see.. that is correct.
scroll down some.
http://www.pdm-racing.com/products/misc_tune.html
Nick O.
97 240sx
Old 04-18-2008, 10:51 AM   #5
SlidewayzDotNet
thanks man you were a big help.
Old 04-18-2008, 10:54 AM   #6
SlidewayzDotNet
good feedback for u
