![]() Join Date: Dec 2007
Trader Rating: (37)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 37 reviews
gas gauge wrong
ok when ever I full tank my car the gas gauge works fine. But when ever I reach under half tank the needle keeps dropping. It drops way under the empty mark. Does that mean the float in the gas tank is bad?
Touke <3 |
![]() Join Date: Jun 2003
Trader Rating: (130)
sounds more like the fuel sender unit has taken a dump. if the float was junk it wouldn't work across the whole range, not just under half.
![]() Join Date: Jan 2007
i agree on a bad sending unit. the level sensor is a rheastat that's built into the tank unit. you can get a new tank unit and use your fuel pump, or just get a whole new assembly, but the pump and the rest of the unit are separate entities
gl man, Dave @ Lethal Injection Motorsports (www.lethalmotorsports.com)
![]() Join Date: Jan 2008
Location: Amerika24 alabama: Where if your not first..... your last
i had a similar problem due to the wiring, but if it just started happening after working fine then its probably the sending unit
![]() Join Date: Nov 2007
Is it stuck? Or just not sending period.
If its stuck, Take out the bobber shake it a few times to get it loose and stick it back into the fuel tank. if its not sending It's a bad sending unit.. |
Like mentioned above check your sending unit. Mine came off the bracket and my guage was AFU first reading full then it was all over the place. After i pulled it and noticed it was in the bottom on the tank I remounted and its somewhat correct.
Not sure but I assume the low level indicator is sent from the sending unit also? Can anyone verify this? (s14) |
#10 | |
Banned from the Marketplace
![]() Join Date: Dec 2006
Like everyone has said, check your sending unit. Let us know if that isn't it. Otherwise, /thread |
I didn't see a point in starting a new thread but I have a similar issue on my base model zenki s14 w/ka...except my fuel gauge works fine but my fuel light never comes on. I pulled the cluster and replaced the bulb and it still doesn't come on. Would this be a sending unit/wiring related issue too? I have a friend who insists that base model s14's do not have the gas light hooked up...I think he's full of it.
-Retired |
base model S14's don't have the light hooked up? every car i've ever seen had a gas light. my old ass 1989 corolla had a gas light. i think he's full of it but maybe im wrong...
have you tried running it dry and the light never came on? A few times my light didn't come on and the entire needle was under the E. i was afraid i would be stranded on the interstate but i figured i still had some time if the light hadn't come on yet ![]() |
