Old 08-25-2006, 05:17 PM   #1
speedstar01
speedstar01's Avatar
speedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the rough
tansmission slipping issues
i recently purchased a second 240sx
i was so happy, has a clean body, one owner, 65k, nice grippy clutch when i test drove it. after about 30 mins(on the way home) the clutch started to slip bad.....the rpms would rev way up and i the car would barely move. slightly pissed i decided to put a clutch in it. i purchased a new OEM stlye clutch kit and put it in this week. while iwas under there i replaced the leaky old slave cylinder and bypassed that nasty clutch dampaner (the same procedure i did with my daily drive S13) i bled the system by myself with a bottle of brake fluid and a piece of rubber line and then again with my father (because i thought the pedal still felt way too soft) . i decide to take it out today and after about 15-20 mins of cruising around the clutch starts slipping again!!! it seems to do it only after it is warm!!! ive only put about 10 miles on this clutch...is the clutch breaking in?? is my clutch master cylinder bad? will it need replacing too? my clutch pedal is also way too soft but i thought it was due to the new clutch....the car shifts perfect without grinding and i cant figure out how to fix this!! please somebody help solve my problem!! thanks guys!!
Matt
speedstar01 is offline   Reply With Quote
Old 08-25-2006, 05:49 PM   #2
vvtisupra
vvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond repute
Send a message via AIM to vvtisupra
try adjusting the pedal rod. Under the dash behind the clutch pedal you can change the rod length. It might be too long so its engaging the clutch even when its not depressed. Since the threaded rod is aiming towards you you'll actually have to go left to shorten the rod. Make sure you undo the lock nuts on the rod. don't set the lock nuts just yet test drive it to where you have it where you want it then set the lock nuts. There is a second bolt (larger bolt) that compresses the spring load and the travel, you can play with that too. That is on the top left of the pedal. you'll have to move the seat back and really get in there, it will make it easier. Try that. Also you probably have glazed your clutch by now so give it some time hopefully it will burn off.
http://www.fuckdrama.com/
vvtisupra is offline   Reply With Quote
Old 08-25-2006, 05:56 PM   #3
aznpoopy
aznpoopy's Avatar
might have an oil leak from the rear main seal on the engine, or the front gasket on the transmission.
Old 08-25-2006, 06:11 PM   #4
speedstar01
to vvtisupra: it is dark out now but i will try playing with the pedal adjustment but that doesnt really explain why it slips only when it is cold...
and to aznpoopy: why would a leak cause tranny slippage?? i have yet to notice any leaks on this low mielage beast (it was quite dry under there) plus when i pulled the tranny off to replace the clutch it was dry in there so i dont think thats it thankfully!!
please keep the ideas coming guys!
Old 08-25-2006, 11:33 PM   #5
C. Senor
C. Senor's Avatar
C. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfection
Send a message via AIM to C. Senor
i dont know if this is a possiblity since you say it grips for a little while, but i had the problem you are explaining, i had a bad clutch fork you might want to check that out...its like 5 bucks from the dealer, and it saved me some money when i bought my car.lol
C. Senor is offline   Reply With Quote
Old 08-26-2006, 07:50 AM   #6
speedstar01
a bad clutch fork? how can that go bad? lol and replacing that means taking the tranny off again!!! *sigh is there any way to tell the clutch fork is bad without removing the transmission?? also who diagnosed the fact that ur clutch fork was bad? could you be a little more specific about your clutch fork?? im baffled!!!!
Old 08-26-2006, 01:23 PM   #7
aznpoopy
aznpoopy's Avatar
a leak would cause clutch slippage because grippy clutch surface doesnt like hot and slick oil.
if the clutch fork is bent or cracked you might encounter problems with engagement as well.
is the master cylinder original?
Old 08-26-2006, 07:03 PM   #8
TURBI
TURBI's Avatar
TURBI is an unknown quantity at this point
I'm having the same problem with the clutch slipping after 15-20 mins of driving. I was told it was a bad pressure plate but now I'm not so sure. I replaced the clutch slave and master cylinders with non factory units and had problems adjusting the pedal too. I did not change the fork but I'm getting a new ACT kit and if it happens after the install, I don't know what the crap I'll do next... buy sr20... mechanics, help?
TURBI is offline   Reply With Quote
Old 08-26-2006, 07:31 PM   #9
johngriff
johngriff's Avatar
only these issues will cause this problem.
Over engaged pedal: Make sure there is 1/4in play at least at the top of the pedal.
Bad clutch (likely)
Bad Pressure Plate (less likely)
Bad Flywheel (least likely)
All other issues with the clutch system will cause it to stick, not slip.
[email protected]
Old 08-26-2006, 10:59 PM   #10
speedstar01
woot! i installed a new clutch master cylinder today and now there is no slippage. i took the car out for about an hour and it feels great. it was prolly an original master cylinder. so my car didnt need a new clutch after all....it was all in the master!!!!!
Old 08-27-2006, 12:47 AM   #11
johngriff
johngriff's Avatar
lol.
You didnt need to. Your pedal was mis-adjusted. If the m/c goes bad, the clutch wont dissengage.
[email protected]
Old 08-27-2006, 08:50 AM   #12
speedstar01
wait so does this mean that my pedal still might be mis aligned?? the car runs great now with no slipping after putting inthat new master cylinder. how do i properly adjust my pedal if it is still off??? TEACH ME!!!
Old 08-27-2006, 08:47 PM   #13
johngriff
johngriff's Avatar
Because you were kind enough to ask, i took some pictures for you.
Here is the Pedal and Master cylinder out of the Car and apart.
When you slide the master cylinder through the firewall onto the pedal it looks somthing like this.
Now, when people say "to adjust the pedal/clutch" they are talking about this fork and threaded stud. Here it is all the way extended.
And all the way threaded in.
After everything is setup, you should have a "dead zone" at the top of the pedal about a 1/4". If it is tight all the way up, it may be too far extended, and halfway engaging the clutch.
So, it may have been too far engaged, and when replacing the mastercylinder, you readjusted the play during the install.... Hence no need to replace in the first place, just an adjustment. When the master cylinder goes bad, the clutch does not slip, it fails to disengage.
JohnGriff
Http://www.rpsport.net
Drifting Clutch
[email protected]
Old 08-27-2006, 08:52 PM   #14
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
mad props.... ^^^^^^^^^^^^^^^^^^^^
i know im gonna go check this out on my car tomorrow
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 08-27-2006, 09:05 PM   #15
aznpoopy
aznpoopy's Avatar
thanks for taking the time to put those pics together. very helpful.
Old 08-27-2006, 09:45 PM   #16
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
Nice post john griff. Thanks. My clutch pedal has been really soft and i was thinking it was the slave cylinder. I bought one and ive been to lazy to change it. If my problems dont get fixed then i will check out what you talked about john. Thanks
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 08-28-2006, 02:40 AM   #17
koukidough
koukidough's Avatar
koukidough is an unknown quantity at this point
wow you are the man
1997 Nissan S14 SE Redtop SR20DET @12psi
1999 Honda Civic Hatch EK9 N/A b16a2 (SOLD)
koukidough is offline   Reply With Quote
Old 08-28-2006, 05:01 PM   #18
speedstar01
oh my lanta!! john griff IS indeed the man! thanks for taking the time to gather the informative pics.
Old 08-28-2006, 11:02 PM   #19
arminder_d
arminder_d's Avatar
arminder_d is an unknown quantity at this point
It seems really wierd that the master cylinder fixed the problem lol. Doesnt seem logical at all. Did it use to just slip when you laid onto the throttle? thats what i take because you said it would over rev. It would point towards a bad clutch but then you replaced yours. When you did the job did you machine the flywheel and replace the pressure plate?
arminder_d is offline   Reply With Quote
Old 08-29-2006, 04:46 AM   #20
g6civcx
g6civcx's Avatar
That's some crazy stuff. Thanks for the pix.
If you notice, the clutch pedal bracket is really thin. It's easy to break it after a while. Check to make sure that the pedal is indeed going in and out, and not side to side.
Old 08-29-2006, 06:36 PM   #21
speedstar01
exactly, EXACTLEY!! thats why im baffled....actually when we took the old clutch out it had lots of life left on it LIKE it had been replaced at one point already (keep in mind this car is a one owner with 65k miles) but we replaced all the components,that came with the clutch kit, anyway. so it did get a new pressure plate and as for the flywheel.... it did not need resurfacing.
i think that replaceing the master cylinder helped to fix my problem because i moved slighty adjusted the clutch pedal without knowing it....
as for the pedal still being a little too soft....im not as concerned about that now because the car is running flawlessly without slipping so WOOT!!!
Old 08-29-2006, 06:46 PM   #22
speedstar01
so has anyone else shared the same slipping issues as me?
Old 08-30-2006, 01:04 AM   #23
TURBI
TURBI's Avatar
I have the same problem, but I just put in new slave and master cylinders. My clutch used to engage when released only an inch but it keeps getting higher so it must be the pedal adjustment. Also why does my car shake when accelerating from a complete stop after driving around for 20-30 minutes. I was told this is from the 15 year old pressure plate I didn't replace when the new clutch went in.
Old 08-30-2006, 11:34 AM   #24
arminder_d
arminder_d's Avatar
That is called clutch chatter. And yes you should have replaced that pressure plate and machined your flywheel when the new clutch went in. Depenting on what shape your pressure plate is in you may have even damaged your new clutch.
Old 08-30-2006, 11:44 AM   #25
trsilvias13
john post alone should go under FAQ
Old 06-20-2007, 07:15 PM   #26
nisans13turbo
nisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nice
Sorry to bring this old thread back but im curious on one question. So its better to have your clutch to grab sooner then later meaning when you press down onto the clutch and release bout 1" or 2 and it catches compare to if the clutches catches high?
Right now my clutch is catching high, and it'll slip if I drive on city road for more then 30mins but if im cruising on highway and stay on one gear my clutch doesnt slip.
Also, when im shifting slowly and constantly stepping on my clutch, I can feel some kind of winding - grinding - smooth vibrates on my clutch peda l, what does this mean?
Redtop
S13
Thanks
nisans13turbo is offline   Reply With Quote
Old 06-20-2007, 07:23 PM   #27
Ninjabread
Ninjabread's Avatar
Is this play including the button/switch that the pedal hits when it is released or is that before?
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 05-01-2008, 07:08 AM   #28
Dirty Habit
Dirty Habit's Avatar
Dirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfection
Sorry to bump this. But I had a question and didnt want to start a new thread. Plus it has some helpful info in it.
For some reason after pulling my 240 out of winter storage, I only have first and second gear. It wont go into any other gear but those two and you dont have to push down on the clutch for it to engage. Would this be a problem a new master cylinder could solve or does it sound like something worse? Thanks.
1982 280zx Turbo
Dirty Habit is offline   Reply With Quote
Old 05-01-2008, 07:18 AM   #29
posdrift240
posdrift240's Avatar
posdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymore
Sounds like your Forks in the transmission have gotten bent or something. Are you able to go into any other gear with the engine not running?
posdrift240 is offline   Reply With Quote
Old 05-01-2008, 07:35 AM   #30
Dirty Habit
I haven't started it up from the winter yet. Could this hinder it also? I need to flush some fluids etc on friday and Ill see what happens.
But it only goes into one and two when the engine is off. Again, without the clutch engaged.
When I rolled it out of the garage I realized what was going on.
1982 280zx Turbo
