Old 12-21-2001, 02:52 PM   #1
NoTuchn
NoTuchn is an unknown quantity at this point
ok, so my 91 s13 has been having problems from time to time with cutting off.  its an automatic, but sometimes (all the time recently) when it idles at a stop light or traffic, it will rev between 1000 to 200 rpms.  i mean, it revs back and forth, and then about the third time, it ill stop all together.  all the lights will come on an so forth. if i keep my left foot on the brake, and rev to 800 or so while im stopped, then i have no problems.  i was wondering if anyone else has ever experienced this problem, and when they did... or if anyone knows what i can do?!? it gets really bad to the point when im just coasting down the road, and the rpms will drop and it shutts off. this is not a good thing in heavy traffic, as you might well imagine. any help would be highly appreciated. thanks so much...
NoTuchn is offline   Reply With Quote
Old 12-21-2001, 03:02 PM   #2
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
Check the alternator, check the wires leading up to it to. I had a similar problem, and the wires leading up to the Alternator were old and decaying, changed them and fixed it. Could also be a Air Flow Meter, try running a ECU check. (instructions on how to can be found at www.240sx.org under FAQ)
ca18guy is offline   Reply With Quote
