Old 05-12-2008, 01:11 AM   #1
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
Question Oil catch can & fpr and headgasket
Ok guys I just have a few questions.
First off, i'm planning on making a 350hp build and i'm not sure if i need an upgraded fuel pressure regulator. do I?
Secondly, do i need a metal headgasket even though the head has never been taken off? Shouldn't the stock headgasket be good enough for my setup as long as the head has never been taken off? meaning that the original seal is strong and everything is tight and formed whithin the grooves.
Thirdly, Should i install an oil catch can? I've heard that higher blowby pressures can cause oil to make its way into the intake manifold through the T-connector.
Any advice is helpful thanks!
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 05-12-2008, 01:53 AM   #2
Dousan_PG
Dousan_PG's Avatar
blowby is bad news
hope u dont have any
fpr is nice
id leave the headgasket how it is , dont wrry about it.
Aaron
Pink GodziRa
Old 05-12-2008, 01:22 PM   #3
SoguRacing
SoguRacing's Avatar
thanks. I guess i didn't mean to say blowby but i should i get an oil catch can or are they just more for looks than performance?
Old 05-12-2008, 01:25 PM   #4
!Zar!
!Zar!'s Avatar
Sr stock has a catch can.
Adjustable FPR helps with tuning. You don't need one really, just make sure you upgrade to a higher output fuel pump.
Leave the HG stock until something happens to it.
Old 05-12-2008, 01:29 PM   #5
SoguRacing
SoguRacing's Avatar
Ok, thanks, already have a walbro 255. +1 for the help
