Old 11-20-2002, 10:57 AM   #1
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
Okay, for those of you with a SR installed and a FMIC... do you have any cooling probs with the stock radiator?  I've noticed quite a few people install the Koyo aluminum radiator and/or electric fans, while others do not...
Is this just a safeguard and one more mod to increase how far you can boost?  Or would you have overheating problems with the stock radiator (since a FMIC will block a good portion of it's direct air contact).  I'm talking about boost range just slightly above stock, maybe 9-12 range.  Thanks guys.
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 11-20-2002, 11:36 AM   #2
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
*not an sr owner*
The US spec radiator is smaller and the SR runs hotter, so a 240 w/ an SR tends to overheat - FM or SM.  The other reason for aftermarket radiators is to get the hoses well lined up.
There are 3 solutions that I know of 1) Al rad.; 2) get SR rad. out of a clip; or 3) run KA auto tranny rad. (it is larger, and you can use the tranny cooler for an oil cooler).
HippoSleek is offline   Reply With Quote
Old 11-20-2002, 04:29 PM   #3
xhdriver
xhdriver is an unknown quantity at this point
actually the stock sr rad from my clip was just as big as the ka's. i live in phoenix az and finished my install in the summer, it was 100+ degrees every day and if i did a stron gpull through the gears the car would heat up even with the electric fans. the stock sr rad was puny, so i got the koyo and the car has never heated up since.
note: i had my front mount and dual elec fans installed since the beginning. a stock rad on a sr running more boost is risky business imo.
xhdriver is offline   Reply With Quote
Old 11-20-2002, 09:19 PM   #4
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (xhdriver @ Nov. 20 2002,5:29)</td></tr><tr><td id="QUOTE">actually the stock sr rad from my clip was just as big as the ka's. i live in phoenix az and finished my install in the summer, it was 100+ degrees every day and if i did a stron gpull through the gears the car would heat up even with the electric fans. the stock sr rad was puny, so i got the koyo and the car has never heated up since.
note: i had my front mount and dual elec fans installed since the beginning. a stock rad on a sr running more boost is risky business imo.</td></tr></table><span id='postcolor'>
yeah my S14 KA rad was same size as the one in my clip I think the only one smaller was early S13s. &nbsp;anyway i did mine over the summer, while not as hot as Arizona we had some 90 degree scorchers and never a hiccup from the car. &nbsp;I've got a single 14" electric fan pulling on mine and thats it. &nbsp;i just as of yesterday put on a greddy 1.3 bar Padiator cap. &nbsp;I'll get a new radiator this spring when I get some more money and throw round two of the power mods at the SR. &nbsp;right now Im still running 7psi. &nbsp;still get some good directed air from the grill between the headlights. (mines hollowed out too) &nbsp;I may fab up a piece to cover all that so the air is FORCED through the rad also.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 11-21-2002, 06:37 AM   #5
HippoSleek
HippoSleek's Avatar
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/blush.gif" border="0" valign="absmiddle" alt=':blush:'>
Sorry guys - I guess that was last year's myth. &nbsp;I remember a lot of discussion about that being the case. &nbsp;In any event, some background:
FA Overheat link
Confusion cleared
Old 11-21-2002, 03:34 PM   #6
Yoshi
Yoshi's Avatar
Hmm... so the answer is split... I know I'm more at risk for overheating, being in a desert climate... it gets down to 0 degrees F (and below) here in winter, and well over 100F in summer, so I guess I should be doing the new aluminum radiator and electric fan thing huh?
On fans... anyone know what kind of performance diff there is tween dual smaller elec. fans vs. one larger one?
Old 11-21-2002, 07:06 PM   #7
DarkRaptor42
DarkRaptor42 is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Yoshi @ Nov. 21 2002,2:34)</td></tr><tr><td id="QUOTE">On fans... anyone know what kind of performance diff there is tween dual smaller elec. fans vs. one larger one?</td></tr></table><span id='postcolor'>
this is just my understanding of the dual electris fans, why get two small ones side by side when you can get two small ones for front and back? Also why not just get two big ones, one on front and one in back? They only cost a little more. From what ive seen the smaller ones cool a wider area but with less air while a big one blows more air in a concentrated area. Im not sure but this just occured to me, couldnt with two smaller dual fans get on to suck and one to blow? or is that what they do? If thats the case I may have been foolish in getting the larger fan.
04 WRX STi
90 Sil- Camino
R.I.P. AE86 20v MS
R.I.P. KA-T
www.209forums.com
DarkRaptor42 is offline   Reply With Quote
Old 11-22-2002, 08:37 AM   #8
Steeles
Steeles's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (DarkRaptor42 @ Nov. 21 2002,8:06)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Yoshi @ Nov. 21 2002,2:34)</td></tr><tr><td id="QUOTE">On fans... anyone know what kind of performance diff there is tween dual smaller elec. fans vs. one larger one?</td></tr></table><span id='postcolor'>
this is just my understanding of the dual electris fans, why get two small ones side by side when you can get two small ones for front and back? Also why not just get two big ones, one on front and one in back? They only cost a little more. From what ive seen the smaller ones cool a wider area but with less air while a big one blows more air in a concentrated area. Im not sure but this just occured to me, couldnt with two smaller dual fans get on to suck and one to blow? or is that what they do? If thats the case I may have been foolish in getting the larger fan.</td></tr></table><span id='postcolor'>
performance diff its pretty much all about the CFMs. &nbsp;kinda like your turbo. &nbsp;the more air it moves the better. &nbsp;aas for one big VS two Small. &nbsp;you'll probably be better with two samll ones. &nbsp;the small ones are gonna spin faster and move more CFMs over a smaller area faster. &nbsp;a big one may move the same cfm but not nearly as fast over a bigger area. &nbsp;I hope that last part makes sense.....stick two small pullers on the back of your radiator and a large pusher on the front. &nbsp;have one or two hooked to your temp sensor and you got enough fans to cool yyou no mater where you are <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
Old 11-24-2002, 09:02 AM   #9
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
On my SR I am running 12-13psi on the stock SMIC and 240sx radiator and have never had an overheating problem (besides the time my damn fan didn't come on while racing @ VIR). &nbsp;Also, the SR rad is the same size different outlet placement. &nbsp;A FMIC will help cooling as long as you are running fan(s) on you radiator. &nbsp;
Just my .02 <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
