Old 05-15-2008, 08:28 PM   #1
Kouki
Kouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud of
HELP! Oil pick-up/no pressure
Alright I need some help. I have a redtop SR. I just changed the stock oil pan to a Greddy pan. That is the only change. Pulled the old pan, used a good razor blade cleaned all the old silicone off, let all the oil drip off, cleaned it real good, used ultra black rtv, installed new pan. I let it sit for about a day so the rtv would set up nice, and filled it up with oil. Let it sit for a couple hours just to make sure it sealed up nice, good to go, no leaks. Well I started up the car tonight, and as soon as I did the oil pressure light was on! WTF, I shut it down right away, went and double checked the oil level, still good. WTF? Any thoughts? I never had any pressure problems before. What holds the pick-up on, is there a chance that it dropped down? I made sure to clean the screen out and make sure that none of the old silicone was in there before I put it back together. What could be the problem? I'm gonna have to pull the pan again tomorrow to check, but thought I'd try to get some advise or push in the right direction before I just start tearing things apart. HELP HELP HELP.
I need to get this fixed in the next day or 2 because I have an event coming up on sunday that I already paid for and is non-refundable.
Kouki is offline   Reply With Quote
Old 05-15-2008, 08:31 PM   #2
drftmark
drftmark's Avatar
drftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura about
did you add the extra quart of oil for the new pan?
drftmark is offline   Reply With Quote
Old 05-15-2008, 08:31 PM   #3
burnsauto
burnsauto's Avatar
the pickup is held on by two bolts, they're only spot welded on the flange...and can sometimes break off. Time to pop off that pan again
Old 05-15-2008, 08:38 PM   #4
cotbu
cotbu's Avatar
Prime, you drained all the oil and let it sit overnight....
Old 05-15-2008, 08:42 PM   #5
slider2828
slider2828's Avatar
Hold on.... prime it again.... LIke he said....
But in case you don't know what that means, pull your fuel pump fues, remove the CAS plug, and crank the engine for 5-10 times. Turn off car plug everything up again and fuse and all and try to start...
Turn and Burn!
Old 05-15-2008, 09:14 PM   #6
Kouki
I primed that cock sucker so much, that is not the issue. I guess I'm gonna have to pull the pan tomorrow and try to figure this shit out. Hopefully the pick-up just had an issue. Any other advise would be great.
Old 05-15-2008, 11:12 PM   #7
Sileighty_85
Sileighty_85's Avatar
heres where the oi pick up connects to
Lowset hanging point
heres with the oil pan and pick up removed
Ignore the captions I posted this for some one else a while ago
you could try crackin the turbo feed line and turn it over to see if its pushin oil
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
