Old 11-29-2002, 06:39 PM   #1
wpayne
wpayne's Avatar
wpayne is an unknown quantity at this point
I was driving down the rode yesterday and I took off from the light a little hard but not all out, when I tried to shift to second, the gear wouldn't go in! I pump the clutch and tried again, then tried all the gears and none worked. I pulled over and coasted to a parking lot where I tried to get the gears to go in, but I couldn't get it out of neutral. So tured off the car and it finally went in with a little force. I just messed around with it for a while 'till it finally went in normall. When i started my car, the car drove fine and everythig except that the car shaked a lot when I started off. So I took it to a mechanic and after checking it out, they said that both my slave and master clutch cylinders were leaking so they replaced it. I got the car back and it still shook when I took it off. So I took my car back and they checked it out again and found that the transmission mount was shot. He said it might cost like $200 to change it but I find that a little hard to believe.
Oh, and on top of that, after the incident when I was driving, the first time I tried to start it again my starter was making noise. So I guess coincidently my starter started going bad at the same time...
sucks to be me...
Too many people use cars as an extension of their PENIS and they make me sick. A car is to get you from point A to point B or for motorsports. Not revving around town at stop lights.
Check out my mods!: 50,000watt super amp and JDM lights!! Yeah right...
S13 Silvia K's I got for free (I'm in japan now)!! Woot woot!
'99 25GT-T Skyline (I don't want to list all the parts) http://welcome.to/skylinegtr
'92 240sx HB
wpayne is offline   Reply With Quote
Old 11-30-2002, 06:53 PM   #2
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
if they have drop the transmission to replace the mount, that price may be right. i think my 240 may need new engine mounts and a transmission mount.
whateverjames is offline   Reply With Quote
Old 12-01-2002, 02:22 AM   #3
wpayne
wpayne's Avatar
Yeah, well turns out it's not the mounts. My clutch is going bad. The mechanic quoted me $550 for clutch, flywheel, throw-out bearing, and a few more things. Do I really need to change all of that?
I'm thinking of just selling my engine/tranny and getting an SR. The engine has only 75k on it and runs beautifully.
'92 240sx HB
Old 12-01-2002, 09:11 AM   #4
whateverjames
It costed me $300 for labor for the clutch install. i don't think you'd have to replace your flywheel just yet. resurfacing the old flywheel was $40 (but i had a new flywheel.) throw out bearing is $20 and they say it's good to always replace that. $550 seems somewhat high. i would ask him how much each part costs and you wouldn't have to replace your flywheel unless it has cracks.
02 Blazer X - 90 240SX w/SR
oh noes
Old 12-01-2002, 09:33 AM   #5
96SEChick
96SEChick's Avatar
96SEChick is an unknown quantity at this point
I got my clutch parts straight from the Nissan dealer and they cost me $120 (for disk, TOB, pilot bearing, etc) and I believe they resurfaced my flywheel, instead of replacing it.  The labor--I'm not sure about (my warranty covered it w/ the Rear Main seal replacement, but 2 local Nissan dealers quoted me $575-$650 to do the entire job--parts & labor.
I would suggest buying an aftermarket clutch or the parts straight from Nissan, and having someone other than a dealer to install them.  Find a reputable service center and you should be able to save a decent amount on labor.
Lauren
'91 300ZX TT Ultra Red 5-speed - JWT POPCharger, JUN flywheel, ACT clutch, Energy Suspension Bushings, Tokico Blues - dyno'ed 295hp/306tq
'94 300ZX TT Black Emerald Pearl 5-speed - JWT POPCharger, JWT ECU w/ Stillen chip, Stillen exhaust, Tokico Blues, Eibach ProKits, 18" Enkei RP-01 wheels - dyno'ed 333hp/385tq
'00 WS6 Trans Am Bright Red 6-speedFOR SALE - only 29k miles, stock, fully loaded, only $23,999 (NADA $26300)
Green Country Motorsports
Northeastern Oklahoma SCCA
96SEChick is offline   Reply With Quote
Old 12-01-2002, 11:09 AM   #6
wpayne
wpayne's Avatar
Yeah, I was quoted $550 from this mechanic. He has a good garage but I don't know how good his peopole are. They always get their parts straight from the dealer and I don't know how much they mark it up.
Wow! $300 is fuckin' cheap! How is just resurfacing the flywheel? Is it just like a shorterm solution?
'92 240sx HB
Old 12-01-2002, 11:57 AM   #7
shrumhead
shrumhead is an unknown quantity at this point
yeah that is pretty damn cheap, I payed about 500 bucks but I also had my oil changed and got new spark plugs and wires.
shrumhead is offline   Reply With Quote
