clutch will not disengage.. Hydraulics work fine
Hey guys.. I can't get my Exedy Hyper single clutch to disengage. It has less than 9k miles on it. Hydraulics work great.. I literally watched my fork moving, and watched the fingers on the pressure plate move.. So everything is working. What could cause the clutch not to disengage????
-Bart |
![]() Join Date: Oct 2004
Did the fork snap? Did the pivot shatter? Check those things... Shine a light and a small mirror inside the slave cynlinder boot on your tranny.
#3 | |
![]() Join Date: May 2005
He said the fingers moved, so the fork isn't broken. Maybe the pedal needs adjusting? Maybe the MC is going out?
![]() Quote:
http://zilvia.net/f/sale-items/24807...-stuff-fs.html |
![]() Join Date: Jan 2004
Do you have break fluid coming out of the slave at all? B/c a faulty slave may still move a little but not enough to completely disengage the pressure plate.
the slave is moving fully. complete travel. pivot is the nismo.. won't break, at least not any time soon. clutch works intermittently. blahhh. im going to drop the trans now.. fuck. previously i had a nice garage to do it in.. but now i have to do it in my slanted ass driveway. no leaks. hydraulics are all new new new
-Bart |
![]() Join Date: Mar 2008
I say clutch pedal, keep adjusting that bitch. I recently had a problem with the clutch not disengaging, imagine driving for 30 miles like that, it sucked. It turned out to be my pedal.
#11 | |
![]() Join Date: Oct 2003
I adjusted the rod and now it engages about 1/2 way off the floor and almost to the top fully. I'd like it lower, but that is due to a clutch in my near future. Without knowing the exact problem it's hard to say, but for about $20 and some time you can replace the rubber line (known to fail) and scratch the dampener (known to hold air)....I think for high end clutches it's mandatory to remove it for some reason. Hopefully your pressure plate didn't fail.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
I'd hate to get my lazy ass to pickup a camera, but I assure you.. the hydraulics work. Nothing collapsed. I have SS lines. No damper.. Hydraulics are fine. No adjustments are needed to anything.. the clutch works intermittently.. no leaks.. no air in the lines... full range of motion...... I'll answer my own thread.. theres something internally wrong. a clip has probably broken, changing the leverage... affecting the disengagement. hahahaha... thanks for the help guys. im about to find out what reaaallly went wrong.
![]() -Bart |
Well we all have to make sure you checked the basics if you didn't specifically tell us
![]() Hopefully it's something you can just fix there, but it's sounding like a component failure.
#14 |
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
I had the exact same problem a couple months ago. Everything seemed to be fine but when I took the lid off the res the fluid looked black and was like water. Flushed it out, put new fluid in, adjusted pedal and it felt like a brand new clutch.
Regards, Robert
![]() 940-683-8282 x20 Robert Del Angel CLICK HERE FOR OUR FACEBOOK PAGE!!! FOLLOW US ON TWITTER!!! Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!! |
