Old 05-26-2008, 03:32 PM   #1
whereda40at
whereda40at's Avatar
whereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nice
Send a message via AIM to whereda40at
broken diff
i was running a stock open diff. at the track last week it broke. what do i need to get it moving agian?
i bought a lsd and someone told me i need more than that???
thanks in advance
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE!
10.79 @ 124 MPH WITH A 1.48 60'
whereda40at is offline   Reply With Quote
Old 05-26-2008, 05:57 PM   #2
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
Are you certain it's broken? What's it doing now? While in gear and under acceleration you don't move anywhere? Do you see the driftshaft spinning? Any grinding noise? Make sure you didn't just bust an output shaft or axle. If it's just an output shaft / axle it's a matter of popping it out and putting another one in. Otherwise, if the gears of the pinion or ring gear is damaged then it's better to source a whole new unit (LSD with output shafts). A 6 bolt is an r200 differential from an s14. Are you asking for an s14 with an OEM LSD option? You can find those readily available at most JDM engine importers. They also have them on ebay. Search "s14 lsd". Good luck.
mmdb is offline   Reply With Quote
Old 05-26-2008, 06:30 PM   #3
apex
apex's Avatar
Trader Rating: (44)
apex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfection
Feedback Score: 44 reviews
+rep sent^
op: we need more info to help u out on what u need or did
Red Rocket
apex is offline   Reply With Quote
Old 05-26-2008, 06:38 PM   #4
whereda40at
the axles are not broke. they are dss 600hp and they are still intact. the driveshaft still spins but no moveing and alot of grinding in the rear.
Old 05-26-2008, 07:27 PM   #5
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
http://forums.nicoclub.com/zerothread/253879
lookup diff
surreybc is offline   Reply With Quote
