Old 06-07-2008, 07:13 AM   #1
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
aluminum crack sealer??
well i overtightened the bolt on the theromostat housing, and cracked the part of the housing that goes into the engine, small hair line crack, but it leaks like a mofo.
so its a pain in the a** to replace the front cover so i was gona epoxy it because its a small hairline crack. can anyone recomend a good epoxy???
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 06-07-2008, 07:23 AM   #2
Ninjabread
Ninjabread's Avatar
jbweld?
haha. don't be ghetto.
replace the cover.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 06-07-2008, 10:40 AM   #3
bloodangels13
bloodangels13's Avatar
bloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of light
Send a message via AIM to bloodangels13
get crack TIG welded.... good bye crack! it will cost more but its the best way to do it
---R.I.P. David Mario Brandt ----
Originally Posted by ThatGuy View Post
This post was brought to you by the number: Rum
And by the letter: Go Fuck Yourself
And also by viewers like you.
bloodangels13 is offline   Reply With Quote
Old 06-07-2008, 10:46 AM   #4
turbo2nr
turbo2nr's Avatar
i would but that would mean taking out the front cover on the ka motor, and i have another fornt cover form my other motor but its a long process, i was gona try to seal it and then if it still leaked then replace it
s14 kouki ka-t
Old 06-07-2008, 11:21 AM   #5
Def
Sand with some 60-80 grit to get a rough surface, thoroughly clean with isopropyl alcohol, apply JB weld liberally. Let it cure 24 hrs before using the car again and it should be fine.
I repaired a radiator with JB Weld in a pinch and it held fine(had a hole in a water tube).
Old 06-07-2008, 12:57 PM   #6
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
WOW!!! talk about back yard B.S. ??? Just bite it and replace it !! Don't be lazy !! Or it will leak and haunt you untill you just replace it !!
WoolyS14DET is offline   Reply With Quote
Old 06-07-2008, 01:02 PM   #7
johngriff
johngriff's Avatar
2nd this.
You'll lose the engine if you drive with that leak guaranteed.
[email protected]
Old 06-07-2008, 01:03 PM   #8
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
jb weld or marinetex. just make sure to clean the shit outta the area before you apply it, and them let it cure for at least 24 hours.
Old 06-07-2008, 01:07 PM   #9
ms!3
if you plan on pulling it later. go ahead and jb weld.
if not, then yea. replace that cover.
ms!3 is offline   Reply With Quote
Old 06-07-2008, 01:08 PM   #10
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
^^^ that should only be a temporary solution.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 06-07-2008, 01:31 PM   #11
WoolyS14DET
Trader Rating: (18)
Id hate to see what other peep cars look like if they are reccomending to used JB weld and not just replace it ??? I would do the correct repair so I wouldn't get or be stuck on the side of the road!! It's your car fix it right !! Would you let some docotor just put a bandaid on a deep gash that would require 100 stitches ?? Don't be cheep about it !! Fix it right !!!
Old 06-07-2008, 01:47 PM   #12
brndck
brndck's Avatar
if i had a ka, i'd have no problem jbwelding stuff. just my .02.
if it doesn't leak then the problem is solved. yes its ghetto but welcome to the land of s-chassis owners.
personally, and since i'm unemployed and have a shit ton of free time, i'd probably pull the cover and go on a cleaning frenzy at the same time.
Old 06-07-2008, 01:55 PM   #13
Folken
Folken's Avatar
Folken is an unknown quantity at this point
Just JB weld it, if it doesn't hold then you know what you have to do, I've had multiple techs tell me they've used it over the years on random cracks and worked great... it's just a KA couldn't hurt anymore then whats happening now
The beatings will continue until moral improves
Folken is offline   Reply With Quote
Old 06-07-2008, 02:29 PM   #14
turbo2nr
turbo2nr's Avatar
haha i like all the its a "ka" jokes..
but anyway back on topic, im pulling the motor at the end of summer to build it, so i don't want the hassle of pulling the front cover off if i don't have to. the reason i plan on using jb weld is because my uncle is a Nissan tech and he look at the and the size of the crack and just recomended to use some jb weld. and if it leaks ill see it obviously, and then ill just change the cover if it does.
i fully understand about half assing my car. but the problem isnt crazy the crack is literary the size of one hair. and the leak is a constant drip not a stream of fluid. but yes if i had the tools and time id replace the cover. that is the correct way.
so back to my original question any more recommendations on a good sealant besides what was mentioned?
s14 kouki ka-t
Old 06-07-2008, 06:45 PM   #15
fbiphil
fbiphil's Avatar
fbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud offbiphil has much to be proud of
Billy Mays says to use Mighty Putty!
On the commercial, he fixes a leak in the Hoover Dam! Not really, but that stuff is wild!
Seriously, though- go with JB Weld. When I worked at Toyota, one of the techs had a rod go through the side of his 22R. He retrieved most of the pieces of the block, put it back together with JB Weld, and rebuilt the engine.
This was 10 years ago, and I still see that truck running around!!
It may not be elegant or the "right" way to go, but it works.
Good luck!
fbiphil is offline   Reply With Quote
Old 06-07-2008, 06:53 PM   #16
BustedS13
BustedS13's Avatar
jb weld that shit
/thread
Old 06-07-2008, 07:29 PM   #17
airsoft
airsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of light
silly putty or bubble gum
JB weld works wonders
However, I recommend replacing as said above
airsoft is offline   Reply With Quote
Old 06-07-2008, 08:29 PM   #18
300hp owen
300hp owen's Avatar
300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold
300hp owen is offline   Reply With Quote
Old 06-07-2008, 09:57 PM   #19
DrFtKiNg240sxy
DrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfectionDrFtKiNg240sxy is close to perfection
^^^^^ HAHAHAHA
DrFtKiNg240sxy is offline   Reply With Quote
