Old 11-25-2002, 12:52 AM   #1
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
I picked up a set of tokico blues/sportlines this weekend, and I was wondering what you guys are running for camber correction in rear and front.  Is a good alignment enough to fix the problem?
rancid240 is offline   Reply With Quote
Old 11-25-2002, 01:56 AM   #2
adey
adey's Avatar
adey is an unknown quantity at this point
afaik, getting an alignment won't help excessive negative camber. Our cars don't have stock camber adjustment up front. Nor does it have caster adjustment, but we do have front toe adjustment. Then again, our definitions of excessive neg camber varies from -2 to maybe -9 (drfthvn) degrees. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
You may consider getting pillowball mounts to replace your worn out upper strut mounts.
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 11-25-2002, 05:11 PM   #3
rancid240
Trader Rating: (72)
I always figured pillow mounts were only for coilovers...damn i should have got a set while i was in japan. &nbsp;I heard installing those camber bushings is a big PITA
Old 11-26-2002, 04:59 PM   #4
turbo240sx
turbo240sx is an unknown quantity at this point
use camber bolts in the front $20 bucks each. and in the back i used whiteline offset bushings in the back. works mint
240sx s-13 TURBO weekend v-8 killer
90 Talon TSI
WARNING.THIS CAR IS EQUIPPED WITH A TURBOCHARGER. DUE TO POSSIBLE BREATHING PROBLEMS UNDER HEAVY ACCELERATION, ALL FEMALES ARE ADVISED TO REMOVE ANY TIGHT FITTING OR RESTRICTIVE CLOTHING FOR SAFETY.
turbo240sx is offline   Reply With Quote
Old 11-26-2002, 05:46 PM   #5
adey
adey's Avatar
I can't recommend this, but I've heard of people slotting/redrilling the top of their two lower strut mounts in front. You know how it's held by 3 bolts up top, and 2 on the bottom? slotting the top of the two bottom ones will let you change the angle at which the shock sits... i'm not sure if this is what people mean by "slotting" though, as i've never had to do that (I have adj. pillo mounts) ...
Old 12-04-2002, 04:50 AM   #6
9524tee
9524tee is an unknown quantity at this point
Send a message via AIM to 9524tee
just get the eibach springs that lower it 1.2 in the front and 1.0 in the rear they ride great and the camber is only off half a degree on my car ... which is perfect for taking corners , and it hasnt shown any weird tire wear ... trust me they ride nice , and it wont mess up the tires at all ...
Nancy Kappa Monkey Squad
9524tee is offline   Reply With Quote
Old 12-04-2002, 07:35 AM   #7
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
ingall has some camber bolts.... so does eibach....
I am GOD!
drifterx is offline   Reply With Quote
Old 12-04-2002, 04:05 PM   #8
rancid240
Trader Rating: (72)
i head those camber bushings for the rear were a bitch to install...how did you guys install them? &nbsp;I am sure the fronts will be a piece of cake
Old 12-04-2002, 04:30 PM   #9
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
I got some Stillen Rear Upper Control Arms for like $130 of ebay. You can get Cusco, JIC, Battle Version for around $250-$320. Its the best way to adjust rear camber, I tried so many times to install the Whiteline Rear Camber Bushings and was unsuccessful every time, they wont allow you to adjust the camber with these, it just moved it a little to help help set it back to the correct setting. Another way is to get a plasma cutter and cut the stock upper control arm IIRC, 240sx.org has something on it in the Installs section.
Then you have front camber. You could use those eccentric bolts, but ive never trusted those things, maybe they work for some people, I never got them to work. Best way to get some adjustability for front camber is to buy some upper pillow mounts that allow for adjustment, Cusco, Tein, JIC are a few that make them, you can catch them on Ebay from time to time for a very good deal. They will also stiffen up your front suspension a little more by allowing the shock to absorb more of the road.
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline   Reply With Quote
Old 12-04-2002, 04:58 PM   #10
rancid240
Trader Rating: (72)
that was a good deal on those stillen pieces. &nbsp;are they the same as the 300zx rear arms? &nbsp;I think i will try some camber bolts up front until i go to japan this summer. &nbsp;as for the rear, i heard that you need a press to get the camber bushings in. &nbsp;as for slotting, i dont think i could ever do that, it just seems so wrong &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'>
Old 12-05-2002, 08:24 AM   #11
drifterx
drifterx's Avatar
why did u buy sportline springs?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>???
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'> &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
I am GOD!
Old 12-05-2002, 01:17 PM   #12
rancid240
Trader Rating: (72)
I got the set for $100. &nbsp;I went mostly for drop. I dont care about handling as much as some of you do, since i dont plan on ever tracking the car.
Old 12-07-2002, 10:02 AM   #13
91CRXsiR
91CRXsiR's Avatar
91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self
Send a message via AIM to 91CRXsiR Send a message via MSN to 91CRXsiR
are sportlines that bad? i
i know they wouldn't perform as well as pro kits but they are still eibach..?
the only reason Ground Controls are even reputable is because they use eibach springs right?
91CRXsiR is offline   Reply With Quote
