Old 06-19-2008, 12:01 PM   #1
ABAKER240
ABAKER240 is not welcome here anymoreABAKER240 is not welcome here anymoreABAKER240 is not welcome here anymoreABAKER240 is not welcome here anymoreABAKER240 is not welcome here anymoreABAKER240 is not welcome here anymoreABAKER240 is not welcome here anymoreABAKER240 is not welcome here anymoreABAKER240 is not welcome here anymoreABAKER240 is not welcome here anymore
testing window mechanisms
is there a way i could troubleshoot my window, the drivers side wont roll up or down, the pass. works fine, if i take my doorpanel off and hotwire the motor it rolls up, i took apart the amp and didnt see any bad connections, and nobody around here has a switch or an amp, so i want to find out for sure what it is before i order both.
ABAKER240 is offline   Reply With Quote
Old 06-19-2008, 12:07 PM   #2
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
well you can use a multimeter to check for continuity on the switch, but my guess is you have a bad amp
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 06-19-2008, 12:13 PM   #3
ABAKER240
i read a write up a while back to fix the amp by re soldering a broken connection, but i didnt see any, can it go bad with no visual signs?
Old 06-19-2008, 12:21 PM   #4
xsparc
xsparc's Avatar
yes but first check for small cracks on the solder joints. you might as well just reheat the solder to make sure they are all good before you start lookig for a new one.
